R50/53 I have 2 questions
Old Aug 25, 2008 | 08:08 AM
05Greenie's Avatar
05Greenie
I have 2 questions
Question 1: When I start my R50 the engine idle ramps to ~ 1100rpms then after the rpms settle down the engine shimmys and shakes like it's going to stall, but it recovers and engine idle is normal ~ 800-900rpms. The engine never stalls. This has been present since I bought the car and never thought anything about it.
Question 2: I am trying to remove the upper and lower grill to use blackout tape on the chrome pieces and using a rachet/socket I try backing off the metal nut and it doesn't seems to back off completly???? What am I doing wrong??? When I tighten the nuts the tension increases like a normal nut/bolt would do, but I cannot get the nut off the bolt...any recommendations?
Old Aug 25, 2008 | 08:37 AM
AutoXCooper.com's Avatar
AutoXCooper.com
?1, yes thats the norm. A TSW engine damper would help and plus put what little power us R50 owners have to the ground better too. http://www.autoxcooper.com/tsw_engine_damper.html
Old Aug 25, 2008 | 05:01 PM
RussellCory's Avatar
RussellCory
Swear. ALOT.
Then go get something to place between the nut and the car body to pry the nut off while you turn it. I used a small set of snips, the wedge shape worked really well. Others have used forks, screwdrivers, or body panel prys.
You probally won't be able to re-use the nut. Zip ties work well if you don't want to go to the dealership for new nuts…
Grizld700
Dec 30, 2015 10:47 AM
donniedarko
Oct 21, 2015 01:15 PM
twriter
Oct 2, 2015 03:14 PM
Carwash
Sep 15, 2015 02:02 AM
marc0011
Sep 10, 2015 10:04 PM
