R50/53 R50 DIY spark plugs
Old Aug 11, 2008 | 07:40 PM
suprtran's Avatar
suprtran
Moderator :: Racing & Competion Forums
R50 DIY spark plugs
Does anyone have a DIY for changing spark plugs on an R50? Thanks.
Old Aug 11, 2008 | 07:50 PM
Xymox's Avatar
Xymox
Nope, but I can offer you this: http://www.lonestarminiclub.com/foru...read.php?t=551
Old Aug 11, 2008 | 10:12 PM
AliceCooperWA's Avatar
AliceCooperWA
It's ridiculously easy!
You need a spark plug socket, a torque wrench and if available, some dielectric grease.
Do them one at a time, so the plug wires don't get mixed up. If you are using oem plugs, they have multiple electrodes and don't need to be gapped, if they are single electrode, then check what the manufacturer says.
Remove plug wire, remove plug with socket and torque wrench (or any ratchet). Put new plug in. (if you don't have a magnetic socket or a socket that holds the plug snugly, use some rubber tubing that will fit over the plug to lower it down and start the threads. Then tighten to correct torque. Put dielectric grease on plug wire connector and plug it back in...repeat on other plugs.
I think that's all...I don't have the part numbers for stock plugs though.
Old Aug 12, 2008 | 07:42 PM
suprtran's Avatar
suprtran
Thanks for the help, but does anyone else have know of a DIY with pics?
maniacalmorgan
Jan 1, 2020 11:20 AM
Oct 7, 2015 08:52 AM
Filmy
Sep 7, 2015 08:27 PM
Sep 2, 2015 09:05 AM
bigserb3
Aug 31, 2015 09:54 AM
