R50/53 30k Maintenance - What's involved?
Old Jun 23, 2008 | 04:47 PM
993's Avatar
993
I tried doing a search, but couldn't really find what I was looking for. Anyway, what does the dealer normally do on this service? Valve adjustments, clutch wear, flushing of any fluids, etc? Thanks in advance.
Old Jun 24, 2008 | 05:28 PM
MINIKB's Avatar
MINIKB
You are due for Inspaction I at 30K miles
Inspection I Undercarriage
  • Change motor oil and filter
  • Check transmission for leaks
  • Check rear axle for leaks
  • Visually check fuel tank, lines and connections for leaks
  • Check condition, position and mounting of exhaust system and check for leaks
  • Check power steering system for leaks. Check fluid level and add fluid if necessary
  • Check steering for absences of play, condition of suspension track rods, front axle joints, steering linkage and joint disc
  • Examine brake disc surfaces. Clean brake pad contact points in calipers. Grease wheel centering hubs
  • Check front control arm bushings for wear
  • Check brake system connections and lines for leaks, damage and incorrect positioning
  • Check for free movement of the parking brake cables. Adjust parking brake if necessary
  • Check and correct all tire pressure (including spare). Check condition of tires, tire wear and pattern; in case of uneven tread wear, adjust wheel alignment if requested (billed separately)
    Engine Compartment
  • Read out diagnostic system
  • Check engine cooling system/heater hose connections for leaks. Check coolant level and antifreeze if required
  • Check level of brake/clutch fluid in reservoir. Add if required
  • Check windshield washer fluid level and antifreeze protection. Add if required
  • Check air conditioner for operation
  • Reset service indicator
    Body / Electrical
  • Check battery electrolyte level and add distilled water if required
  • Perform battery load test
  • Check lighting system. Including headlights, fog, parking, reverse, license plate, interior (including map reading lights), glove box, flashlight, illuminated makeup mirrors and luggage compartment area lights.
  • Check instrument panel and dashboard illumination
  • Check all warning/indicator lights, check control
  • Check turn signals, hazard warning flashers, brake lights, horns, headlight dimmer and flasher switch
  • Check wipers and washer system, wiper blades and washer jet positions
  • Check condition and function of safety belts
  • Visually examine the airbag units for torn covers, obvious damage or attachment of decals, decorations or accessories
  • Check central locking/double locks
  • Replace batteries for alarm remote controls in all master keys
  • Oil hood, trunk and door hinges. Grease hood, trunk/tailgate and door latches. Check operation of all latches.
  • Replace microfilter
  • Check heater/AC blower, rear window defogger
  • Check rear view and side mirrors
  • Activate automatic roll-over protection system (if equipped) via diagnostic link. (Note: First remove hardtop/lower top)
    Final Inspection
  • Road test with check of brakes, suspension, steering clutch/manual transmission or automatic transmission
Old Jun 24, 2008 | 08:01 PM
993's Avatar
993
MiniKB -
Thanks a lot for your post.
Rich
Sep 10, 2019 09:22 PM
vulkandino
Oct 31, 2015 08:29 PM
torpeau
Oct 8, 2015 11:10 AM
pkillur
Tires, Wheels, & Brakes
Oct 1, 2015 03:59 AM
