R50/53 Fender liner attachment screws
Old Mar 2, 2008 | 11:22 AM
ScottinBend's Avatar
ScottinBend
Anyone have the part number for the fender liner screws? The plastic phillips head ones.
realoem.com wasn't real clear on what goes where in the diagram.
Old Mar 2, 2008 | 12:04 PM
Poppa Bear's Avatar
Poppa Bear
According to this page over on RealOEM.com, that would be item number 6, expanding rivet, with 07130702966 as the part number. Hope that is correct because I'm needing a couple of these after today's brake job!
Cheers!!
Old Mar 2, 2008 | 04:57 PM
ScottinBend
Yep.....that's the page I was at too. I just wasn't sure which one was the right one.
Thanks !
Old Mar 2, 2008 | 05:02 PM
COR BLMY's Avatar
COR BLMY
I now buy those in lots of 10 ...even 20
They really arr not made for multiple use.
When they are "difficult" I put a new one in.
Old Nov 10, 2010 | 09:54 AM
JT911's Avatar
JT911
When they are "difficult" how do you get them out?
Old Nov 10, 2010 | 10:56 AM
pdflint's Avatar
pdflint
Mini-Mania also has these available in packs of 10 (I believe).
I have cut the head off of a "difficult" screw with a utility knife and pushed the remainder back into the hole. This section often just drops to the ground. Depends on which screw you need to remove.
Old Nov 17, 2010 | 07:43 AM
Vollgas's Avatar
Vollgas
Page Auto Supply also has them.
BernieCoop
Sep 10, 2021 03:15 AM
Elusiv
Sep 21, 2015 08:53 AM
jcb-memphis
Sep 16, 2015 05:45 PM
Elusiv
Tires, Wheels, & Brakes
Sep 14, 2015 11:23 PM
