R50/53 Agressive Driving questions
Here is another site on downshifting:
http://www.turnfast.com/tech_driving..._heeltoe.lasso
That site also has some other good articles.
See ya,
JS
See ya,
JS
I havent gotten my mini yet....but i am in the racing business, and downshifting isnt bad for your clutch, but doesnt do any good either. If you are paranoid about ruining your clutch, use the heel-toe method. :smile: :smile:
Dan
Dan
<snip>
For those that can dance, here's something you might like to read:
http://www.edmunds.com/ownership/how...2/article.html
See ya,
JS
http://www.happytogether.com/318ti/notebook/shifting/
This guy gets into some of the technical stuff, like why you should blip the throttle in neutral (with the clutch pedal UP, BTW) .
Ok, Ok, I was thinking that I knew how to drive my 911 and my MCS, but now I
am not sure.
_________________
DMonk - MCS w/ Prem/Sport/Cold Tint 35%
BMP Racing Filter/Strut Tower Brace Polished/Whalen Shift ****
Stubby silver Antenna/Kick *** wheels-n-Tires(See http://www.rspeed.net)
am not sure.
_________________
The compression on our cars is not really sufficent to slow the car tremendously so you're wearing out transmission parts for generally little benefit. The good news here is that when driving at high speeds at the track your downshift into your exit gear you will be less likely to unsettle the balance of the car. Smooth is good. The bad news is that if/when you overheat your brakes downshifting is a less useful/effective temporary braking alternative than in other cars with higher compression engines.
Save the hard "deceleration" downshifts for other cars or for emergency situations only. Rev match when you have to do it.
Regards,
Jim
Regards,
Jim
am not sure.
am not sure.
Have fun!
Always look ahead-brake shortly before you come to the turn then do your downshifting & matching rev's to power through the turns-the MINI's tranny is very smooth, much different than other sports car I have driven but just as much fun.
Went to Phil Wicks Driving Academy last week. Well worth the $ & the effort.
Good luck,
Lois
_________________
Good luck,
Lois
_________________
One thing that's always puzzled me is that people often talk about double clutching and to me it seems like that it would take so much longer to accomplish a shift??? Although, I can really see how it would probably help a lot when trying to shift down 2 gears from 5th or 6th...coming through the gate, it often takes me a longer time to find the gear I'm going for. Trying quickly do a U pattern coming through that wide throw to the right where 5th & 6th reside is tough.
Also heel-and-toeing in the MINI seems like it would be quite a stretch...unless my size 10.5(U.S.) shoes are just too small? I remember when I first got my MCS, I was eager to try it out and then quickly realized it seemed like the brake was nowhere near being close enough to the gas pedal...after one attempt and realizing I couldn't find/reach the gas, I haven't tried since.
alistaircookie
Oct 8, 2015 10:52 AM
