R50/53 W11B16A Engine Displacement
Hello all! If the Mini engine have a bore x stroke: 85.8mm x 77mm bore, how did Mini/BMW come up with 1598cc (1.6 Liter)? Shouldn't it be a 1781cc engine (1.8 Liter)....
you are right...
i used an online displacement calculator to figure it out...
Engine Displacement Calculator by Bowling and Grippo
Input Parameters Are the Following:
Computed Engine Displacement (CID) is 109
Computed Engine Displacement (Litres) is 1.8
Computed Engine Displacement (CC) is 1780.8
I wonder what there smoking over there in england...
- Number of Cylinders are = 4 to 1
- Piston Diameter = 85.800 Millimeters
- Piston Oversize = 0.000 Millimeters
- Engine Stroke = 77.000 Millimeters
Also, speaking about the +05 Cooper S W11B16A factory valve. BMW/Mini service manual says:
Intake OD Valve: 31.9mm
Intake Stem OD:
Exhaust OD Valve: 25.2mm
Exhaust Stem OD:
My buddies at Ferrea say's it's nowhere near that size??? Guess, I will have this measured with a friends motor out for built up.
Intake Stem OD:
Exhaust Stem OD:
New & confirmed update on W11B16A specs:
BORE: 77mm
STROKE: 85.8mm
DISPLACEMENT: 1597.6cc (1.6 Liter)
R/S Ratio: 1.56
MPS @ 7000rpm: 20 Meters per Second
MPS @ 8750rpm: 25 Meters per Second
Intake Valve OD: 30.25mm, Stem OD: 5.95mm, Overal Lngth: 109.5mm
Exhaust Valve OD: 23.25mn. Stem OD: 5.91mm, Overal Lngth: 118.3mm
1597.63
BORE: 77mm
STROKE: 85.8mm
R/S Ratio: 1.56
1597.63
Aug 21, 2015 10:07 AM
finn
Aug 21, 2015 07:59 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
