R50/53 Calling Out Yakima Roof Rack Owners
Old Jun 16, 2003 | 07:58 AM
sambusik's Avatar
sambusik
Can you give us an updated review on how the Yakima roof rack is doing on your MINI since you've gotten it installed?
Things I'm interested in finding out are:
- sunroof clearance - can you open the sunroof with the rack mounted
- how's your weather stripping doing? Is it damaged/coming off
- how easy is it to remove/remount the rack
- any other good or bad things you have to say about it
and of course, pics would be very helpful
Old Jun 16, 2003 | 12:09 PM
sambusik's Avatar
sambusik
bumping to keep on front page in case some Yakima owners see it...
Old Jun 16, 2003 | 03:29 PM
Pebbles's Avatar
Pebbles
I don't have the rack, but I think your thumbs up baby is one cute happy baby!
Old Jun 16, 2003 | 09:28 PM
XAlfa's Avatar
XAlfa
Couldn't tell you - no tengo. I think I've read that it clears though.
Weather stripping seems unaffected, although the trim along the edge of the roof is definitely deformed a few mm when the clamps are torqued. Seems to come right back, though. Why didn't MINI build the roof with real gutters!?!
Very easy, once you set it up. Takes me 60 secs to put in on, 30 to take it off. I keep my steelhead bike tray attached, which keeps the 2 bars connected and centered. I just wipe off the roof and slap it on.
Good:
- Very cost effective when compared to stock rack (<$200 "installed&quot, and more and better accessories.
- Easy to remove. Seems like the stock rack is a major operation to remove and install.
- No holes drilled in your roof - no little cap/cover things when the rack is removed.
- Low wind noise, even without a fairing
Bad:
- Probably not as solid as the stock rack and only "rated" for 75lbs. (Although this is more than enough for a couple of bikes, boards, skis, etc.)
- Narrow spread. Yakima reccommends 18", I set mine at about 21". Could be a problem for a kayak or other long, high-windage items.
It's perfectly fine for light "sports" use, but I wouldn't reccommend it for hauling lumber day in and day out.
Old Jun 16, 2003 | 11:46 PM
sambusik's Avatar
sambusik
XAlfa,
thank you very much for a very informative post. i think many of us out there are looking into alternate roof racks because the factory rack costs an arm and a leg installed (some dealers still charging 9 hrs labor!!)
My biggest concern was the weather stripping, but it's good to hear that it's not majorly affected, especially since the rack is easily removeable.
thx again!
Old Jun 17, 2003 | 09:59 AM
XAlfa's Avatar
XAlfa
No problem. Again, the weather stripping across the top of the door seems fine, it's the plastic trim piece along the edge of the roof that is bent a bit by the clamps.
Old Jun 17, 2003 | 10:19 AM
sambusik's Avatar
sambusik
^^ yeah, that's what i meant, I was incorrectly calling it the weather stripping. thx!
Aug 14, 2015 11:13 AM
Aug 14, 2015 11:11 AM
Aug 12, 2015 01:24 PM
Accessory Products
Aug 11, 2015 12:59 PM
