Off-Topic :: Autos Interested in discussing other autos? This is the place!
Flooded Engines: DIY Remedy?
Old Feb 10, 2007 | 12:55 PM
shankrabbit's Avatar
shankrabbit
It's hella-cold here in WI, (avg. -4F at night). My wifes 1988 Honda appears to be flooded due to this crappy weather.
We just got it back from the shop (unrelated) and I don't want to have to tow it anywhere just for them to change some plugs and do whatever else they do. :impatient
I've tried the little tricks of trying to start with the pedal to the floor, but that baby just doesn't want to start.
Is there anything else I can do? Or am I just going to have to get that POS towed again!?
Thanks for your help in advance.
Old Feb 10, 2007 | 06:39 PM
kenchan's Avatar
kenchan
i would roll it into a warm garage.
but are you sure it's flooded and not cranking dry?
put in ON position for 10sec or so and crank it... might
might not help.
Old Feb 10, 2007 | 07:35 PM
shankrabbit
If only I had a warm garage to roll it into. One very big downfall of still living in an apartment... outdoor parking only.
Pretty sure it's not dry, took the spark plugs out today and the tips were a bit wet.
Old Feb 10, 2007 | 09:31 PM
kapps's Avatar
kapps
If you can get an extension cord over to the car, an engine block heater might to the trick.
Old Feb 12, 2007 | 01:01 PM
thatatvguy's Avatar
thatatvguy
Older Hondas are sensitive to spark plug condition. Also, if there is not enough cylinder pressure, ie. compression, it will be difficult to start. If the battery is good and the motor is turning over at "normal" speed, I would check this.
Old Feb 12, 2007 | 01:24 PM
shankrabbit
The battery is good and it's turning over like normal.
The plugs are 2 years old now, so I suppose changing those wouldn't hurt.
How would one go about checking compression?
Old Feb 12, 2007 | 01:38 PM
kapps's Avatar
kapps
There are kits you can get. Sears has one and I'm sure the regular auto stores should as well. Basically, you pull a spark plug and insert a pressure sensor. When you crank the engine, it'll tell you how much compression that cylinder made. After doing this for all the cylinders, you can see if the sompression is consistent for all the pistons.
Old Feb 12, 2007 | 01:55 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
A quick shot of starting fluid usually gets things going even in the coldest weather.
Old Feb 12, 2007 | 02:08 PM
shankrabbit
Like such? : http://www.valvoline.com/pages/produ...asp?product=41
Old Feb 12, 2007 | 02:36 PM
BRGPA's Avatar
BRGPA
If the plug tips are wet with gas I'd take them inside and dry them out or maybe even use a match to heat/dry them- then give it another try.
Old Feb 12, 2007 | 02:47 PM
shankrabbit
Took the plugs out again to look...
There was a bit of oil on the top of them... where the wire boot meets the ceramic of the plug.
Why do I have a feeling this is not good?
Old Feb 12, 2007 | 02:57 PM
kapps's Avatar
kapps
Originally Posted by shankrabbit
Yeah, if it's getting a spark, that'll get it started. You local auto store will have a variety of brands.
I'm not sure about the oil on the plug. It could be from the valve cover gasket. Best to do the cheap stuff first. Replace the plugs and try starting fluid.
Old Feb 12, 2007 | 03:32 PM
MaxN's Avatar
MaxN
Reverse Gear
Stick the plugs in the oven for a while - on a decent level of heat - take them out with an oven glove and replace them quickly and try to start it again.
Some days it ws the only way i could get my CJ started when I lived 'back east'
Old Feb 13, 2007 | 09:27 AM
Greatbear's Avatar
Greatbear
Sometimes when an engine is just too damn cold, not spinning fast enough while cranking and the fuel is of questionable winter blending, there will end up being insufficient fuel vapor to ignite by the spark. The fuel stays liquid, coating the inside of the cylinder and just sits there. Starting fluid does it's magic by remaining as a volatile vapor even in a cold engine full of raw gasoline. Once a spark hits, the stuff fires off, creating instant heat and burning off the liquid fuel and gets the whole combustion process started. Note that this stuff is extremely flammable. Use only small amounts, a couple of puffs into the intake to start with is usually sufficient. Do not spray for more than a few seconds at a time. Crank for several seconds, if the engine does not catch, try once more. It should eventually light off.
Old Feb 13, 2007 | 09:33 AM
shankrabbit
So what you're saying is...
Small amount = engine ignition
Too much = engine incineration
Duely noted. Thanks for the advice with that stuff (I've never used it before)
Old Feb 13, 2007 | 01:16 PM
Greatbear's Avatar
Greatbear
My main concern aside from personal safety is that in a MCS engine, you will be filling the entire intake tract with volatile gas, and should the engine backfire (which is common when coaxing a cold, flooded engine), the blower, intercooler and all the associated piping will bear the brunt of it. With a small amount at a time, it should not be a problem if this happens.
Old Feb 13, 2007 | 01:42 PM
shankrabbit
My main concern aside from personal safety is that in a MCS engine...
Oh Noes!
The MINI is running great... it's my wifes 1988 Honda that's flooded.
..but still something to keep in mind.
Old Feb 14, 2007 | 11:44 AM
Greatbear's Avatar
Greatbear
Oh, an Accord? Spray the whole can in there and stand back.
I misread the original post. That makes it much easier and less of a worry. Short, simple intake tract. Hold the gas pedal about 1/4 open after hitting the air inlet with the spray. If you've got spark, it should rumble to life.
Since we are on the subject of starting fluid, never use the stuff on a diesel engine except as a last resort, and at that, use it very sparingly. Since a diesel engine controls it's speed/power delivery by controlling fuel flow only, adding fuel in the form of starting fluid can make a diesel engine run uncontrollably for as long as there is starting fluid vapor anywhere in or near the intake. You will not be able to shut off the engine via the ignition key. In fact, if there is too much starting fluid being drawn in and burned, the engine could over-rev and come apart.
This is a public service announcement.
Old Feb 14, 2007 | 12:02 PM
kapps's Avatar
kapps
hehehe. We used some starting fluid to get a VW diesel going when the fuel pump wan't primed. It ran for a few seconds on straight fluid. The smoke that came out of the tailpipe was pretty awesome too . A couple weeks later, the timing belt broke but that didn't have anything to do with the starting fluid (more, the loose nut behind the wheel )
Old Feb 14, 2007 | 12:17 PM
shankrabbit
Close... a Civic.
I'll take pics after the whole can goes in from a mile away. Maybe get a little of the mushroom cloud in there too.
elverado
Jan 18, 2022 02:51 AM
M7Speed
Oct 1, 2015 07:05 AM
micromini234
Sep 30, 2015 07:36 PM
whowantstorace
Sep 27, 2015 06:16 PM
Sep 14, 2015 12:48 PM
