Off-Topic :: Autos Interested in discussing other autos? This is the place!
rust holes
Old Oct 26, 2006 | 09:21 PM
justintime's Avatar
justintime
rust holes
so I stripped the carpet and all paneling from the CRX today and discovered a couple of small rust holes!! a;sldkjasdf
I have no idea what to do about them, I cant weld that thin of metal, not that skilled yet haha. what do you do???
Old Oct 26, 2006 | 10:02 PM
kenchan's Avatar
kenchan
Rustoleum. then layers of aluminum tape... (?)
find a friend that knows how to weld...
Old Oct 26, 2006 | 10:19 PM
justintime's Avatar
justintime
I have yet to find anyone who can weld such thin metal haha. does rustoleum stop the rust from spreading or actually make it dissappear?
Old Oct 27, 2006 | 06:55 AM
MedicMan55's Avatar
MedicMan55
Rust that is coming to the surface means there is alot of rust underneath. You should get that checked out, or the car will be eaten alive!
Medic
Old Oct 27, 2006 | 08:02 AM
justintime's Avatar
justintime
Medic
see I think its the opposite way around. water got into the car and sat back there for a while.
Old Oct 27, 2006 | 08:54 AM
kapps's Avatar
kapps
Check our por15.com for some good rust preventative paint.
Old Oct 27, 2006 | 11:47 AM
kenchan's Avatar
kenchan
rustoleum will only stop the metal from rusting further at the location
you sprayed.
if there's heavy rusting somewhere you can't visually see, it will
still spread like cancer...
Old Oct 27, 2006 | 02:22 PM
justintime's Avatar
justintime
thats it.. keep in mind not all the brown stuff is rust haha. the majority of it is this mysterious fuzz stuck to some tar sheets of some kind.
that too I would like to remove but its rediculously stuck
Old Oct 27, 2006 | 02:33 PM
kenchan's Avatar
kenchan
yikes
Old Oct 27, 2006 | 02:44 PM
justintime's Avatar
justintime
yikes
word
what sucks, Is I just found them a;dlkjfasdf
Ive already done so much work on it its gotta be fixed somehow :impatient
Old Oct 27, 2006 | 04:33 PM
lambspeed's Avatar
lambspeed
It may not be as bad as it looks. Mostly surface rust. Your best bet is to sand blast the area clean. If their is rust or actual holes you can cut those out and weld in new sheet metal. If not just etch prime and your done.
www.lambspeed.com
Oct 1, 2015 12:34 PM
Oct 1, 2015 12:28 PM
Oct 1, 2015 12:13 PM
