Official BMW M5 Pics and Info
Some things to remember:
> Naturally Aspirated V10 (created by some of the same BMW Motorosport engineers that work on the F1 engine program)
> 507bhp/520Nm of torque
> 8250rpm redline
> 8 minute laps at Nürburgring
> 205mph top speed without limiter
> 7 speed SMG transmission
(Updated with US info) Woodcliff Lake, NJ, July 2, 2004...It has been 20 years since the launch of the first BMW M5. After three generations, more the 35,000 sales and countless attempts by competitors to emulate its performance and success, the BMW M5 still makes its position as the benchmark. Each successive generation has extended the bounds of both performance and luxury. The last generation M5, the most successful ever, significantly pushed the performance envelope with the first V8 from BMW M, mated to a six-speed transmission.
The all-new fourth generation M5 pushes that envelope even further with the first V10 engine to power a production sedan. The new V10 produces 507 horsepower and 383 lb-ft of torque by European measure. This new engine is mated to a seven-speed SMG transmission. With this new powertrain the M5 offers the best power-to-weight ratio in its class. In the tradition of BMW M, the chassis has been engineered to keep up with the power while the exterior treatment is subtle, yet distinctive.
First high-revving engine to be featured in a production sedan
This is the first application of a V10 engine in a regular production sedan, if it's possible to call any product from BMW M "regular." It once again sets the benchmark in its class. This engine was engineered to rev, with a redline of 8,250. With 25 percent more power than the previous M5's V8, this new engine offers 100 horsepower per liter of displacement, pure race car territory. The 90o V10 is designed for maximum stiffness and minimum vibration.
The new V10 features double-VANOS variable valve timing. Each cylinder has its own electronically controlled throttle butterfly. The new MS S65 engine management system uses the most powerful processors currently approved for use in automobiles. It has been designed specifically to deal with the V10's high output and high revs as well as the comprehensive controls that are required.
Seven-speed SMG gearbox features Drivelogic
The driver of the new M5 is able to maximize the potential of the new V10 engine with a seven-speed SMG gearbox. Like other BMW SMG gearboxes shifts can be made from either the lever on the center console or the paddles on the steering wheel. Compared to the previous SMG, gear changes happen 20 percent faster with this latest generation SMG, making for smooth, crisp shifts.
With Drivelogic, at the driver's disposal are eleven program options. This enables the SMG's shift characteristics to be tailored to suit the driving situation and the mood. Six of these programs can be selected in the sequential manual gearbox mode (S mode). These programs adjust shifting speed and style because, in the S mode, the driver does all the shifting. In the Drive (D mode) the transmission shifts automatically, depending on which of the five programs is selected, the driving situation, the road speed and the position of the accelerator pedal.
Taken together the drivetrain of the new M5 provides truly awe inspiring performance. From rest 60 miles per hour will be reached in well under five seconds. The rush of acceleration never lets up until the electronically limited top speed of 155 miles per hour. The top speed may be limited but with the speedometer reaching all the way to 205 mph, the mind conjures intriguing possibilities.
The perfect blend of ride comfort and agility
The M5 has long been known for handling that matches its performance, carefully blended with impressive ride comfort. More than just a "tuned" 5 Series suspension, the aluminum suspension on the M5 has been engineered to match its performance. The suspension is mated to 19-inch wheels with performance tires. Keeping power on the road is critical, so the M5 features the Variable M differential lock. By constantly monitoring and comparing the speed of the rear wheels, the Variable M differential lock can ensure that power gets to the drive wheel with the most traction even in extreme driving situations. Its benefits are particularly apparent when accelerating out of a corner.
The Dynamic Stability Control system in the M5 has been designed to suit its performance. Of course, the DSC can be deactivated at the push of a button. The M5's DSC also offers the choice of two driving dynamics programs. One allows DSC to function the way it always has. At the touch of a button, the M Dynamic Mode is engaged which lets DSC facilitate more spirited driving.
To ensure that this level of handling does not compromise ride quality, the new M5 features Electronic Damping Control, with three program modes (comfort, normal, sport). EDC constantly adjusts the suspension to suit the driving conditions.
To complement its performance potential, the M5 is equipped with generously sized high performance brakes with perforated compound brake discs. The aluminum twin-piston brake calipers have been designed for minimum unsprung weight and maximum stiffness. They will haul the new M5 to a stop from 62 mph (100 km/h) in under 120 feet and from 124 mph (200 km/h) in just under 460 feet.
Styling is subtle but purposeful
In the tradition of BMW M, the exterior styling of the new M5 follows the "wolf in sheep's clothing" philosophy. The casual observer may not, at first glance, recognize the M5's performance potential. The less casual observer instantly will. The modified front spoiler and rear apron are instant giveaways. So too are the modified side sills. The wheel arches are more prominent in order to house the generous wheel and tire package. Following BMW M's recent traditions, the new M5 has more aerodynamic exterior mirrors, four tailpipes and exclusive wheels. Similar to the latest M3, the M5 features exclusive gills incorporated into the front fenders.
The exclusive leather interior features sports seats. Other styling touches, from the instrument cluster to the center console and the steering wheel are all unique to the M5. Even the optional head-up display is M-specific.
The all-new BMW M5 once again combines the comfort and amenities one expects of a luxury sedan with the performance capability and driving experience that can be provided by few cars of any type. For more details as well as images, please go to the BMW PressClub at www.press.bmwgroup.com.
Incredible.
The new M5 also features a new DSC traction control system specifically developed for the car. Offering three settings, the default mode offers drivers the high levels of performance and stability you would expect of a car wearing the ‘M’ badge. But by pressing the DSC button once the car reverts to M Dynamic Mode to allow an enthusiastic driver the ability to push the M5 to the absolute limits of traction, even permitting some sideslip and countersteering. If the DSC button is pressed again and held down DSC is completely disengaged.
Originally Posted by DiD
It would be nice if they'd offer something like that on the MINI. :smile:
That's my guess anyway.
Originally Posted by Gabe
I guess it makes a little more sense in an application wwhere the car is rear wheel drive and has lots of power. I mean you can't really power out of a turn in a MINI - unless you're going backwards
True, but it would still be nice to have a "sensitive" and a "less sensitive" version of DSC.
Originally Posted by dandp
Those wheels! I assume it will be SMG only?
Personally - I LOVE the E34 M5....and I even saw an E28 back on Memorial Day. How odd the interior looked on it, looked almost antiquated by today's "standards" While I have seen many complain about the designs of the new 5 & 7 series , if you go back in the time machine and look at how they have evolved - the original versions of theses sedans look very different than last "un Bangled" version. I imagine the E60 M5 in black is going to look intense....
BTW here's a US spec E28 M5
After having had a 2004 M3 with SMG II now for the past 9 months I would not be one bit disappointed if I never had a car with the third pedal again. I look forward to another M5 and the new E60 looks and sounds (on paper) sweet! I’m just a bit disappointed in the torque numbers, but the proof is in the pudding. I hope it is faster then the new E55 AMG which is down in the horsepower but up in the torque departments compared to the M5. I am sure the M5 will handle and drive better. And BMW, lose the iDrive please!
I think the other key is that this engine is a true masterpiece of engineering. BMW doesn't just slap on a supercharger to a big V8 like some other German automakers do. This is a high revving V10 with over 500hp! So while you may be down on torque in you've got a rev happy 10 cylinder engine to more than make up for it
http://www.bmw.com/generic/com/en/pr...se_1/main.html
oooofffaaaaa! that E34 M5 with the Alpina wheels is gorgeous. the e28 wtih the '90s era 8-series wheels looks damn good too! i'm a sucker for the classics. riiiiiight, i drive a MINI
http://www.canadiandriver.com/news/040705-1.htm
[size=1]Munich, Germany - BMW has released photos and details of the new M5 high performance sedan. The new M5 features a 507 horsepower V10 engine which redlines at 8,000 rpm, and provides a 0 to 100 km/h sprint in less than five seconds.
The M5 reaches 200 km/h after a mere 15 seconds and has an electronically limited top speed of 250 km/h (155 mph). If maximum speed was not electronically limited, the M5 could reach 330 km/h, says the company.
The M5 also features a new seven-speed SMG gearbox. As before, gears can be changed using a shift lever on the centre console or paddles on the steering wheel, but compared to the previous SMG transmission, changing gears is 20 percent faster with the new SMG, says BMW. With the SMG's drivelogic function, the driver can choose from eleven gear change options, which enable the driver to adapt the SMG's characteristics to their own style of driving.
The M5's suspension and its electronic assistants have been either exclusively developed for the new M5, undergone extensive modifications or adapted to the special M performance, says the company. The new brakes with aluminium twin-piston sliding callipers provide braking from 100 km/h to 0 in under 36 metres.
Other new features of the M5 include DSC with two selectable driving dynamics programs, Electronic Damper Control with comfort, normal and sport modes, and a variable, torque-sensing differential lock.
The M5 comes with a leather interior in three different colours, different from the 5-Series. Other differences versus the 5 Series are the instrument cluster, the optional M-specific head-up display, the steering wheel with MDrive buttons and the redesigned centre console.
[/size]
[/size]
tacticalbacon02
Aug 22, 2015 06:05 PM
