Navigation & Audio Adding an active subwoofer to my R60, install options?
Old Jul 18, 2019 | 07:20 PM
shred_flanders's Avatar
shred_flanders
Question Adding an active subwoofer to my R60, install options?
Hello,
My 2012 R60 is the base audio package, so I decided to pick up this fella from Amazon:
Amazon Amazon
Don't really want to deal with replacing the head unit, it sounds like more trouble than it's worth.
I was going to install it under the seat but it looks like it might be too big. So failing that, my plan B is to put it in the compartment under the trunk.
There's a 12V plug in the trunk, so I was thinking of yanking it for a power/ground feed. However the wire gauge looks a little thin. The manual for the sub recommends 10GA, I'm fairly certain the wiring for the 12V is less than that.
Am I crazy for thinking this will work, or should I just quit being lazy and wire it properly?
Old Jul 18, 2019 | 07:25 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Wire to battery with fuse close to battery. 12v plug is way too small.
Old Jul 31, 2019 | 10:24 AM
snwmble's Avatar
snwmble
you might want to see if it'll fit underneath the passenger side front seat. I had a similar issue when I was mounting an amp (thinking it would fit underneath one of the seats), but it didn't
Under the pass side seat, beneath the carpet, there is a pocket there where I was able to just fit my amp. I forget exactly how much room is there but worth a shot
mark225
Jul 28, 2019 05:18 AM
Zephyrgtw
Navigation/Audio
12
Oct 21, 2016 11:33 AM
Zephyrgtw
Oct 23, 2015 06:48 PM
bmanferlife
May 31, 2013 07:03 PM
Dropdeadjay
May 21, 2009 01:06 PM
