Navigation & Audio [eas] Official DICE High Definition Radio (w/ iPod support) Q/A thread
Old Aug 20, 2007 | 01:49 PM
  #76
tom @ eas's Avatar
tom @ eas
Originally Posted by Uncl3
I have an 05S with a build date of 7/04 and SV #26-04 42. Based on this assumption, this is not text compatible. But is the radio compatible with dice just for HD radio and no text?
The HD DICE relies on text to operate - it would not be compatible with your radio. The standard DICE kit will be fine in your case.
Old Aug 20, 2007 | 02:17 PM
  #77
tom @ eas's Avatar
tom @ eas
Originally Posted by Sin MINI
That's the funny part. It doesn't matter. The other day I left the iPod in overnight. When I started the car, it picked up right where it left off. Went to work. Had to run an errand a couple of hours later...iPod/DICE went stupid, had to find where I left off again. Really bugging me...
That also is annoying that I should have to do that...is that normal? Anybody else have that problem?
The iPod didn't drop the connection that time around, this is an iPod issue and not the DICE.
Try testing with another iPod or if you have a backup of your music - perform a restore.
Old Aug 20, 2007 | 02:22 PM
  #78
tom @ eas's Avatar
tom @ eas
Originally Posted by frumpysf
I've had the same problems too w/ my ipod resetting itself like that. I'm also annoyed that half the time, the text display isn't functioning. Last night, I disconnected the battery to get my HD unit working again. But still, the text isn't displaying 100% of the time.
When my display isn't working properly, it only has the letter "M" and will occasionally 'scroll' through the text title, using that 1 single space where the "M" is at.
Should I be worried? Or should I send this unit back for an exchange?
Are the DIP switches both set to the OFF position? If you would like us to test the module, we would be happy to let you know if there were any problems.
Old Sep 8, 2007 | 02:36 PM
  #79
Sin MINI's Avatar
Sin MINI
Any word on that new antenna?
Old Sep 8, 2007 | 08:18 PM
  #80
tom @ eas's Avatar
tom @ eas
PCB boards are on the way - very shortly.
Old Oct 2, 2007 | 10:26 PM
  #81
Sin MINI's Avatar
Sin MINI
Any word? It was first mentioned as imminent in June...
Just curious.
BTW, I ve discovered that I can't "rewind" with my MFSW buttons...I can run something forwards, but nat backwards. Been that way for a while...ideas?
Old Oct 3, 2007 | 12:02 PM
  #82
tom @ eas's Avatar
tom @ eas
Just curious.
Still investigating a solution at the moment on the text display w/ NAV - we'll be able to dedicate more time as soon as SEMA is over.
I've seen the "rewind" issue before - usually a reboot fixes this:
1. Disconnect iPod from cable
2. Remove battery cables, negative first
3. Touch battery cable terminals together (away from battery) for +5 seconds, a small spark is normal as this is stored power draining from the system.
4. Allow cables to remain disconnected for about 5-7 minutes
5. Reconnect battery cables onto battery, negative last.
6. Reboot iPod by pressing on MENU and CENTER buttons for +5 seconds and then reconnecting to the DICE cable after the reboot process is completed.
Let me know if these steps correct the problem
Old Oct 4, 2007 | 07:59 PM
  #83
mrskippy's Avatar
mrskippy
"Still investigating a solution at the moment on the text display w/ NAV - we'll be able to dedicate more time as soon as SEMA is over. "
Gotta love hearing this!
-Scott
Old Dec 11, 2007 | 11:14 AM
  #84
tom @ eas's Avatar
tom @ eas
Stealth Antenna kits are completed and now shipping! Full details are in post #3 of this thread.
Old Dec 11, 2007 | 11:26 AM
  #85
lsnover's Avatar
lsnover
Tom, so this setup will work with the HK System on my 05? The stealth antenna is an "option" I take it? And it's compatible with the 3g Nano?
Glad to see this is ready!
Regards,
Lee
Old Dec 12, 2007 | 02:34 PM
  #86
Edge's Avatar
Edge
AdMINIstrator
Nice, Tom!
Just curious - do you also sell the "regular" antenna separately?
Old Dec 12, 2007 | 03:11 PM
  #87
tom @ eas's Avatar
tom @ eas
Originally Posted by Edge
Nice, Tom!
Yes, standard HD DICE antenna kits are on our site:
DICE High Definition Radio Antenna
http://www.europeanautosource.com/pr...roducts_id=926
Old Dec 13, 2007 | 12:48 PM
  #88
lsnover's Avatar
lsnover
Tom:
Where does this antenna install of a 2005 Mini with the HK Sound system? Do I need the extension cord or not? If so, what's the part#/URL?
Thanks,
Lee
Old Dec 13, 2007 | 04:41 PM
  #89
tom @ eas's Avatar
tom @ eas
Originally Posted by lsnover
Tom:
Thanks,
Lee
This depends on where you have the HD DICE module. If it is located within 36" of the radio module, no extension cables are needed.
Old Dec 13, 2007 | 06:09 PM
  #90
lsnover's Avatar
lsnover
I don't have a HD Dice module yet. I want to get one with the new "stealth" antenna. So where would it be installed on an 2005 with the HK sound system? I.e. what are the parts I would need to order to do a full install?
Thanks!
Lee
Old Dec 13, 2007 | 07:13 PM
  #91
tom @ eas's Avatar
tom @ eas
Thanks!
Lee
Lee,
Here are the items you would need:
DICE High Definition Radio w/ iPod Integration (MINI)
http://www.europeanautosource.com/pr...roducts_id=608
eas - Stealth Antenna kit for DICE High Definition Radio
http://www.europeanautosource.com/pr...oducts_id=1566
These items will get you High Definition radio in the MINI without an exposed HD antenna on the windshield. Be sure to order the optional iPod cable if you would ike to integrate your iPod.
Old Dec 17, 2007 | 08:25 PM
  #92
90STX's Avatar
90STX
How to install stealth antenna?
I've had the HD radio / iPod adapter installed for about a year, and wondered how the new stealth antenna installs. I've never been happy with the placement of the stick-on windshield antenna that came with the kit, though I otherwise love the setup.
Scott
90SM
Old Dec 31, 2007 | 03:30 PM
  #93
90STX's Avatar
90STX
bump for an unanswered question. How does the stealth antenna install? Does it just hook to the HD module, or does it also connect to the MINI radio?
Thanks.
Scott
90SM
Old Dec 31, 2007 | 03:43 PM
  #94
tom @ eas's Avatar
tom @ eas
Thanks.
Scott
90SM
The Stealth Antenna module connects to bot hthe MINI radio and HD DICE module, using the stock antenna instead of the external HD DICE antenna.
Old Dec 31, 2007 | 07:26 PM
  #95
90STX's Avatar
90STX
Thanks!
Scott
90SM
Old Jan 6, 2008 | 11:53 PM
  #96
Sin MINI's Avatar
Sin MINI
Had to reset the stupid unit again with the battery-disconnect process. I'll let you know how it goes but at the moment I'm not pleased.
Biggest issue is the inability of the unit to simply pick up playing the iPod where it left off. I have multiple 1hr+ podcasts that I listen to as I go to and from work. The trip is short and takes multiples to complete the podcast. Problem is, almost every time the unit either plays the first song on the unit I (which I am getting sick of), or it may actually remember the podcast directory but starts with the first episode rather than the one I was listening to (they list in reverse order...newest first...I like to listen in order, which is bottom first). Then I have to pull over...find the right podcast, and then search for the point at which I left off. Needless to say this is agravating...I'm usually at work by the time I find it. I've flat given up using the unit for anything but long (1+hr) drives 'cause it ain't worth the hassle.
The iPod always remembers where it left off...why does the DICE have to get in the way?
Old Jan 6, 2008 | 11:56 PM
  #97
Sin MINI's Avatar
Sin MINI
How long is the car shut down before the memory is lost? If the iPod goes into Deep Sleep mode or is disconnected, all "bookmarks" are lost.
Why should there be bookmarks? The iPod always remembers where it left off...not sure the DICE has to get in the way of that.
As for the ffd/rew, reboot the iPod and reconnect - you will gain these back.
Nope. Sorry.
Old Jan 7, 2008 | 10:35 AM
  #98
tom @ eas's Avatar
tom @ eas
The iPod simply cuts off communication to the dock connector in hibernation mode - breaking the handshake between the DICE or any other device.
Old Jan 7, 2008 | 01:25 PM
  #99
Sin MINI's Avatar
Sin MINI
Still doesn't make sense...way too hard and way to unreliable
Old Jan 7, 2008 | 01:46 PM
  #100
tom @ eas's Avatar
tom @ eas
Not understanding doesn't make a kit "unreliable", but feel free to contact me by phone if you would need an explanation in real-time.
