Navigation & Audio MINI "ding" noise help
Old Apr 2, 2007 | 07:09 PM
dubsdj's Avatar
dubsdj
Hi, I have a Mini cooper with Sat Nav optional extra.
anyway, can somebody tell this: When I slow down into first gear, eg when I reach a junction .... Why is it when I pull away , I hear an audio "ding" noise.....
please , does anybody know what this is?
Old Apr 2, 2007 | 07:16 PM
ncdave's Avatar
ncdave
I don't have Sat Nav, but the Mini will give off an audible "ding" if the ambient outdoor temperature reaches 37 degrees or lower to warn of possible road icing. You didn't state your location - could that be a possibility? It's a little easier to hear when you're going slowly - it could explain why you only seem to notice it in first gear. Just a thought!
Old Apr 2, 2007 | 07:54 PM
GLJones's Avatar
GLJones
Check the Speed setting in the setup menu. It is designed to "ding" when you exceed the speed you set (I use it to remind me to slow down on a certian road on the way to work, the cops hide on it). Turn it off, or set it to a much higher speed, and it should stop.
Old Apr 2, 2007 | 07:58 PM
Eric_Rowland's Avatar
Eric_Rowland
GLJones' explanation makes sense. The speed warning is on the second 'page' of the Nav OBC.
I that's the case, you should see a flashing number at the bottom of the Nav display with the speed you've exceeded.
I can't think of any other reason for a repetitive ding, unless it's a malfunction.
Old Apr 3, 2007 | 06:14 AM
dubsdj's Avatar
dubsdj
thanks
I think you're right , it must be the speed setting in the sat nav... thanks again I will check that out
Getrieben
Sep 12, 2024 07:03 AM
maestro39
Oct 27, 2015 02:38 PM
kitty90034
Navigation and Audio
Aug 25, 2015 12:47 PM
nismo4life
Aug 5, 2015 08:31 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
