Navigation & Audio Aftermarket SIRIUS
Old Jan 29, 2007 | 09:26 AM
1caliente's Avatar
1caliente
Aftermarket SIRIUS
I have a 2005 with the HK radio. I added an aftermarket radio with Sirius to my last car, and now can't stand "free" radio. Can I use the Sirius module from my old JVC radio in my Mini? Are there any after market Sirius modules that will work with the HK radio? The dealer wants $1K for the upgrade, 500 for the radio 50 for antenna, 50 for install kit, 2.5 hours @ $150 per. Seems high. I like the look of the built in unit and the display on the head unit, so built in would be my first choice over adding a stiletto outboard, Feed back please
[FONT=Times New Roman][SIZE=3] [/SIZE][/FONT]
Old Jan 29, 2007 | 11:58 AM
checkers's Avatar
checkers
I have the factory nav system, and the dealer said i could not add the sirius radio. So i went to Best Buy and had them put in. I have the sportster model. It fits just fine, i had them mount it under the switch panel. It works great.I still have the stock H&k system that works fine also. The only way you can tell i have sirius is the antenna that i had locatated just behind the radio antenna, it's so small you really dont see it.
I forget to mention they charged me about $75.00. for installation.
Last edited by Edge; Jan 29, 2007 at 03:49 PM. Reason: Merged back-to-back posts (NO content editing)
Old Jan 29, 2007 | 12:44 PM
tom @ eas's Avatar
tom @ eas
You cannot use an aftermarket-specific tuner for an OEM application.
You should not require a new radio tuner, here is the kit you need:
Sirius Satellite Radio - MINI Cooper/Cooper S
http://www.europeanautosource.com/pr...roducts_id=635
This will include everything needed for installation.
tom @ eas's Avatar
tom @ eas
Your dealer is incorrect also, Sirius can be used with NAV.
Old Jan 29, 2007 | 03:50 PM
Edge's Avatar
Edge
AdMINIstrator
Indeed it can (check my sig). The only issue is that you can't use the OEM SIRIUS antenna with factory Nav, because they don't make a combined SIRIUS/GPS antenna for the MINI. You just have to use an aftermarket antenna... but you get 100% OEM functionality.
Old Jan 29, 2007 | 03:58 PM
tom @ eas's Avatar
tom @ eas
Correct - we include a mini Sirius antenna with our kits.
Doc Pain
Oct 28, 2015 07:09 PM
Qik420
Oct 4, 2015 08:19 PM
Tires, Wheels & Brakes
Oct 1, 2015 02:50 PM
simo711
Oct 1, 2015 05:36 AM
