Navigation & Audio 2nd gen iPod solution?
Old Jan 7, 2007 | 08:20 AM
Aeromax's Avatar
Aeromax
Does anyone here use a 2nd gen ipod in their mini? Is there a good solution, or am I limited to using my FM modulator?
Old Jan 7, 2007 | 09:59 AM
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
What do you consider the 2nd gen iPod? The one with the touch pad wheel but no dock connector?
If so, the best solution is use the AUX port adapter and a miniplug cable between the AUX port and the headphone jack on the iPod. I used to run this way with my last car. You pretty much have to ramp the volume all the way up on the iPod in order to get any real volume out of the setup.
Old Jan 8, 2007 | 12:12 PM
Aeromax's Avatar
Aeromax
Well, I have an 02 radio. So, I suppose in that case I'm just best off using the FM modulator I already have.
Old Jan 8, 2007 | 05:36 PM
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
You could always check the Marketplace for someone selling their stock HU that would accept a AUX jack. They seem to pop up pretty frequently.
Old Jan 8, 2007 | 07:08 PM
tom @ eas's Avatar
tom @ eas
Or even better, the DICE:
DICE iPod Integration Kit for MINI Cooper/Cooper S
http://www.europeanautosource.com/pr...roducts_id=314
Old Jan 9, 2007 | 06:44 AM
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
While that would work it wouldn't give you any of the iPod interface functionality. It would just be a $150 AUX jack. The 2nd generation iPod lacks the dock connector (that didn't come around until the 3rd gen).
Old Jan 9, 2007 | 02:02 PM
tom @ eas's Avatar
tom @ eas
It would give you everything with exception of text display on the radio, since the radio does not support text. All other features are still present.
Old Jan 9, 2007 | 05:27 PM
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
While all the functionality would be there with the DICE it would be wasted on a 2nd generation iPod. The 2nd generation doesn't have the dock port which the DICE uses to control the iPod. Instead it has a firewire port which was used for computer syncing and charging, a headphone jack, and a remote control connection which was built into the headphone jack. And just to head things off at the pass, the remote control connection on the 2nd generation iPod is nothing at all like the dock on the 3rd gen and newer, it didn't offer anything even remotely like the functionality the dock connector does.
Old Jan 9, 2007 | 05:42 PM
tom @ eas's Avatar
tom @ eas
You're correct - I misread the post, the 2nd Generation iPod (Classic iPod) does not have the dock connector.
jwmolmen
Oct 19, 2015 05:48 PM
deep72
Sep 16, 2015 08:53 PM
Emnotek
Sep 11, 2015 04:16 PM
Eurothrasher
Sep 9, 2015 12:00 PM
Accessory Products
Sep 9, 2015 10:29 AM
