Navigation & Audio Aux Input (I'm sad)
Old Mar 23, 2007 | 11:45 AM
  #26
Loony2N's Avatar
Loony2N
Originally Posted by jdjeff58
Well, I guess we need to hear from the other 45 million...don't we. But my 2 to your 4 is 50%.
Actually, your 2 to his 4, is 33%.
Old Mar 23, 2007 | 01:32 PM
  #27
rkw's Avatar
rkw
Originally Posted by Louispup
ARgggh. Now I'm having problems with the Aux port. It's been flickering in and out, even with another ipod, so it's in the port, or the HU. Sometimes AUX cycles through (used to always) but now it's just vanished. And when it WAS on for a few moments, it just dropped and went to CD.
Are you powering the iPod from the car (e.g. cigarette lighter)? If the problem goes away when you run the iPod only from its battery, this is almost definitely caused by a ground loop. The remedy is a ground loop isolator. It is a common problem on the aux port and you will find lots of information if you search the forums for "ground loop isolator".
Old Mar 23, 2007 | 01:38 PM
  #28
myzamboni's Avatar
myzamboni
OP-
I had this problem at first as well. Believe it or not, what I thought was complete plug insertion into the Aux. input was not. check to see if you can push your plug into the Aux. input port further than it currenlty is (it is a very snug fit). I have not had any issues since I resolved this.
Old Mar 23, 2007 | 01:39 PM
  #29
Louispup's Avatar
Louispup
The ipod is powered by the battery in the ipod. I've never had any problems in my one year with it. the ipod was charged yesterday, and last night I noticed the aux jack thread (?) was loose so I tightened it by hand and AUX appeared again. Today the AUX availability has been spotty. Used to be Solid. Thanks for your suggestions.
Old Mar 23, 2007 | 02:27 PM
  #30
rkw's Avatar
rkw
This could be a loose connection inside the jack. Plug in a cable and try jiggling the plug and see if it has an effect.
Even with no player or cable plugged into the aux jack, you should always be able to select AUX mode on the headunit. If you can't, there is probably a bad connection in the aux cable wiring or the plug isn't completely seated.
Old Mar 23, 2007 | 03:08 PM
  #31
Louispup's Avatar
Louispup
Got it. I was tempted to do a "things you didn't know about your MINI" regarding: Did you know if your ipod isn't hooked up, the AUX option won't cycle?
rikaro
Nov 24, 2015 02:05 PM
eliseo1981
Nov 2, 2015 11:24 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
BossyR56
Sep 28, 2015 11:33 AM
