Navigation & Audio Base vs. HK system....
#26
Originally Posted by Crashton
The MA adjusted the H/K for me so it wasn't too boomy. Too me it was & IMHO wasn't worth the $500 cost. I did play with the settings, but couldn't find a setting that was worth $500 to me. Your milage may vary. I'm glad you enjoy your H/K system.
Chuck
Chuck
Best line in the whole thread.
#27
This thread reminds me of something I once heard during a discussion on HDTVs. What do you call a person that can't tell the difference between High Def and standard TVs??? LUCKY! They get to save a ton of money buying TVs. I always recommend people listen to the HK system first. If it meets their needs and they can tell the difference between it and the standard system, then get it. If they want more, go aftermarket. Just remember, HK doesn't play well with others. It's a bastard to integrate with aftermarket components!
#28
Do you want a true HK system or what is sold to BMW/MINI with a cool name? The HK system in my MCoupe is less than impressive and I would rather spend the $550 on any other upgrade than the sound system. The HK speakers in my car have cardboard cones which after awhile just fall apart. And because 3ohm midrange speakers like that are unique you have to go back to BMW and buy crazy expensive ones from them.
YIKES
My vote is to buy a nice aftermarket system if you are an audiophile, otherwise stock is fine. I actually laughed at my MA when she suggested the HK system for my Cooper S. So I have stock.
H
YIKES
H
#29
I like the H/K system... I wanted a upgrade over the basic system but still wanted it to look OEM.... not aftermarkety.... and I wanted it done...not have to screw with it after I get the car...
H/K does just that... 8 speakers and an Amp.... clear sound...nice bass.... fully adjustable....and at $500 bucks... that is going to be less than your going to spend on a head unit, speakers, amp to throw in...
#30
#31
Originally Posted by davisflyer
I am getting ready to order my 06 MCS. Just to preface, I am not interested in going aftermarket at this time. That being said, is the HK system worth $500 over the base cd stereo. The car I test drove had the base stereo and it seamed clear, with well balance tones. I've read a lot of threads about the HK recently that people don't like it, yet on Edmunds.com, they call the HK one of the best factory systems they have heard.
Thoughts anyone......
Go for it...the money isn't much compared to the amount of time you'll be using it. It does sound great.
#32
Some one suggested this here or on mini2 - make a cd with some of your favorite tunes on it. Take it the dealer and listen to it on both systems... That's what I did and I immediately knew I wanted the h/k. That's the only way you'll know.
After years of putting in aftermarkets in my Civics I didn't want to start taking apart my new MINI
#33
go for the H/K
We opted for it on our 06 MCS; it is a great stereo and I'd order it again if I was placing an order today.
One disappointment: the MCS coupe we test drove had the base system, but I wanted to hear the H/K. The only test driver available at the moment was a cabriolet, we took it for a drive and really loved the sound of the H/K. I was particularly impressed with the speed-sensitive volume (where it automatically increases volume with speed--owner's can adjust the amount of boost). However, when we picked up our MCS coupe, we learned that the speed-sensitive volume only comes on the cabriolets. It doesn't make sense to me because the price of the H/K is the same whether it is a coupe or cabriolet.
So, does anybody know if this is a hidden feature that I can turn on by pressing the right buttons?
#34
My pre-HK 2002 Cooper has an adjustable speed-sensitive volume contol. To adjust it I press and hold the note button, then the display changes to "TONE LIN" and I press it again until the display changes to "SPEED VOL", then I turn the **** to make my selection from 1-6 (the higher the number the higher the increase in volume).
#35
Unfortunately you can't. I also have the H/K stereo in my '05 MCS hardtop and adjusting the speed sensitive volume is simply not an option. My wife owns a '02 Cooper CVT with the standard factory stereo and she does have the speed volume option.
shorenetworks
09-20-2015 08:46 AM
