Navigation & Audio Add subwoofer to stock Boost Headunit
Old Dec 20, 2004 | 07:45 AM
fj0's Avatar
fj0
How can I go about on doing this? I've tried searching but most people type sub and you cant search on that, sorry.
Apreciate any help I can get, thanks in advance!
Old Dec 22, 2004 | 03:37 AM
fj0's Avatar
fj0
noone?
Old Dec 22, 2004 | 04:38 AM
Pebblecrusher's Avatar
Pebblecrusher
Pay a professional like Tweeter (regional name I believe). Personally I think my H/K stock system has too much bass as it is, but to each his own. :smile:
Old Jan 4, 2005 | 09:39 AM
spillman's Avatar
spillman
You will need a signal converter and a seperate controler for your amplifier to adjust the level of output. Simply tap into the positive and negative speaker wires of your rear 6x9's and plug the rca wires into it. If you have a cooper s it will be very simple to install the positive and negative cables since the battery is located in the rear. If your's is not an S then you will have to go about runing the positive wire through the "cockpit" somehow. You can tap into the rear cigarette lighter plug in since it turns on with the ignition for the amp "turn on." However you go with a higher end JL Audio amp they have automatic amp turn ons. They require no "turn on" wire. If you have no experience with this then I wouldnt recommend doing it without the supervision of an experience person or just let a professional do it for you.
wkp1219
Nov 13, 2015 07:52 AM
SunnySideUp
11
Aug 26, 2015 06:42 AM
flredmini
Aug 12, 2015 06:35 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
