ID4 to ID5 Retrofit Completed (MINI F56 JCW ).... Happy Carplay User...
  #76
Old 09-04-2021, 05:11 AM
SPZERO's Avatar
SPZERO
SPZERO is offline
Hello, I have a Mini Cooper F56 from the year 2015, it has a NBT id4 system with a 6.5 "screen, at the same time, I also have a NBT EVO HU id6 system with a 8.8" touch screen, I could change one for another directly or I need to do something else? Thanks.
  #77
Old 09-04-2021, 05:15 AM
Dragos V's Avatar
Dragos V
Dragos V is offline
You need to activate the id6 evo on the bench with carplay and all and then replace the NBT unit.
You have NBT not NBTevo id4, right?
NBT doesn't have OABR plug so you cannot inject FSC. You can only code it.
  #78
Old 09-04-2021, 05:17 AM
SPZERO's Avatar
SPZERO
SPZERO is offline
It's just NBT.
  #79
Old 09-04-2021, 05:21 AM
Dragos V's Avatar
Dragos V
Dragos V is offline
It's just NBT.
So you have 3 options:
1. Put evo id6 replacing NBT and you need to pull out from the quadlock the Ethernet wires to create a OABR plug. Then u can code it, activate CarPlay etc..,
2. Put evo id6 in a BMW or MINI car that already have evo unit, activate it there on your vin, inject fsc, etc , then move it to your MINI
3. Put evoid6 on bench and do all the activation , carplay etc on the bench then retrofit NBT
Cheers
  #80
Old 09-04-2021, 05:23 AM
SPZERO's Avatar
SPZERO
SPZERO is offline
Cheers
Thank you very much for your help, I will study what to do. All the best.
  #81
Old 10-30-2021, 06:41 AM
omulec's Avatar
omulec
omulec is offline
Hi everyone. I read this thread and some others and need your word (don't know if I understand correctly)
My car is a 2017 F55 with Visual Boost radio and Satellite Radio, Mini Connected and Phone. VIN is WMWXU1C57J2F80627.
1. I suppose I will need a NBT HU unit with SW at not lower than 3.1, right to run id5 or id6 without problems. And I suppose it has to be coded to my car. Is that right?
2. I will try to find 8,8" touch screen, but that will be not easy. From what I understood, new NBT will work without touchscreen on my 6,5" or on 8'8" non-touch - but again it needs configuration coding?
3. I suppose I can upgrade to touch controller with additional module for that. But I can stay with the original from my mini?
4. For all above - are there any wiring, or additional hardware needs?
Can you confirm, or explain a bit more?
  #82
Old 11-10-2021, 08:05 AM
boki's Avatar
boki
boki is offline
Originally Posted by sb2002
PMd
Hi sb2002 - PillPusher84 from here recommended me to contact you about this - I tried PM's but I believe your Inbox is full so I'll just post it here.
I have a '19 f56 with 8.8" touch screen and I'd like to flash the latest GUI/software for that fresh new look. I saw some photos and I like the look of the new interface/GUI much better than my current one. I believe I should have all the hardware already and from what I understand I would only need someone to help me flash the latest software on the head unit. Is that correct? Can you help me with that and how much would you charge me? I live in Bronx/NY - are you close by or you'd do the work remotely? You can PM me if you prefer.
Thanks in advance.
  #83
Old 11-10-2021, 08:16 AM
sb2002's Avatar
sb2002
sb2002 is offline
Originally Posted by BIMMER-REMOTE.com
PM sent
But you aren’t sb2002.
  #84
Old 11-10-2021, 08:23 AM
sb2002's Avatar
sb2002
sb2002 is offline
Thanks in advance.
PM’d.
  #85
Old 11-10-2021, 08:46 AM
boki's Avatar
boki
boki is offline
PM’d.
Thanks, appreciate the fast reply.
  #86
Old 11-26-2021, 06:38 PM
NY1mini's Avatar
NY1mini
NY1mini is offline
F55 parts needed?
Looks like a lot of info in this page. I just purchased mini f55 2019 anybody could tell me my options? VIN WMWXU3C54K2H86789
  #87
Old 12-17-2021, 09:26 AM
bcorgan's Avatar
bcorgan
bcorgan is offline
Hello,
i would like to know if there is a risk if one the car has a problem, i need to go the MINI DEALER and they detect my new unit
i would to know if they can refuse the car because its not the original unit and screen?
i have a f54 jcw from 2017
thanks
  #88
Old 01-07-2022, 07:40 PM
ktherobot's Avatar
ktherobot
ktherobot is offline
If anyone reading this is interested in a retrofit similar to Sarath's, please pm me. I was part of the group of people that helped Sarath with this retrofit and am posting here with his permission.
I have a 4 gigabyte NBT Evo originally from a Mini (that uses the blue GPS connector, so no ATM is required) and an 8.8" Mini touchscreen that I would sell, and I can help with the necessary flashing/coding of the headunit to make this essentially a plug and play process.
Please let me know if you have any questions, and I'm able to provide references if you're interested.
Hi i made a retrofit it works so far but i havent code stuff how much would you charge me its working but the led ring is not as well i want to upgrade to the newest version mine is a nbt id4 and wants to flash to id5
  #89
Old 01-07-2022, 10:09 PM
johnny13's Avatar
johnny13
johnny13 is offline
Can anyone help me update ID4 to ID5/ID6 (I have a 2016 F55 with ID4). I can't do a remote access to PC, but I can be walked through the updates with esys.
Thanks,
  #90
Old 01-08-2022, 01:13 AM
Dragos V's Avatar
Dragos V
Dragos V is offline
Thanks,
hi mate.
sure. Ping me i can help you!
  #91
Old 01-20-2022, 03:02 PM
GermanFabian97's Avatar
GermanFabian97
GermanFabian97 is offline
Hello everyone,
I come from Germany and have already researched a lot on this topic on the Internet. However, I am an absolute layman and would hire a capable mechanic for this project.
However, I need to know what to do in general and in particular which parts I need.
I drive an F56 JCW from 2015 with 8.8" non-touch screen with all the functions that were available at the time. I am interested in converting to the 8.8" touch screen (with CarPlay, and everything that is new).
What is necessary for this? What do I have to buy, what must be done on the vehicle?
Thank you very much for the information!
Greetings from Germany
Fabian
  #92
Old 01-20-2022, 03:30 PM
varma1986's Avatar
varma1986
varma1986 is offline
Originally Posted by GermanFabian97
Hello everyone,
Fabian
You can reach out to a seller by name NAVIBMWPARTS on eBay & YouTube to help you out with parts & coding.
  #93
Old 04-12-2022, 05:36 PM
mlucca1's Avatar
mlucca1
mlucca1 is offline
I have a mini countryman s f60, want to get apple carplay. The system you have can i put in my countryman? Also, the price?
Thanking you in advance
  #94
Old 06-09-2022, 04:29 AM
yaaaaaron's Avatar
yaaaaaron
yaaaaaron is offline
Does anyone have the 03-18 psdzdata package for id4 to id5 for US spec cars?
  #95
Old 06-09-2022, 04:44 AM
Dragos V's Avatar
Dragos V
Dragos V is offline
I wouldn't recommend 18.03 for id4 to id6 mini. That's stable only on BMW id4 to id6.
For mini id4 to id5 flash i would go with 17.11.
  #96
Old 07-17-2022, 05:49 PM
nodrog321's Avatar
nodrog321
nodrog321 is offline
I have a 2017 F56 JCW with a 8.8" screen. whats my best option for carplay? the ID4 -> ID6 with partial screen carplay? If I want a stable full screen carplay, would i need to get the mmi module add on? If I use this add on, will my factory back up cam/sensors work as it does now or does it use the mmi's interface?
  #97
Old 07-17-2022, 05:54 PM
yaaaaaron's Avatar
yaaaaaron
I would not recommend the MMI modules, they are laggy and are cropped in the mini's curved sides. My 2017 Cooper S now has fully functional, native Carplay and now thinks it's a 2017 Clubman haha. If you don't feel comfortable doing the coding yourself (it isn't too hard) you can pay people to do the service for you. Your backup cam and sensors will work without a hitch as mine do. FlashXCode is my preferred vendor for these sorts of things.
nodrog321 (07-17-2022)
  #98
Old 07-17-2022, 05:57 PM
sb2002's Avatar
sb2002
sb2002 is offline
Flashing from ID4 to ID6 will result in occasional reboots if you use factory GPS as well.
Other options include retrofitting a native ID5 NBT Evo with your existing screen using an older firmware - you would still be limited to splitscreen CarPlay, but it would be stable while using factory GPS. You could also retrofit a native ID5 NBT Evo and a touchsceen, which would allow you to have the latest Mini user interface, fullscreen carplay, and reliable factory GPS.
The downside to these solutions is price, but please let me know if you have any questions. I have parts and lots of experience with similar retrofits.
  #99
Old 08-17-2022, 12:48 AM
ovzfz's Avatar
ovzfz
ovzfz is offline
Hello guys, so i got 2015 MCS with the basic radio (orange LCD) and i really want to have a touchscreen with Android Auto and Carplay. what are my options? can someone point me on the right direction? my VIN is WMWXP7C58F2C60105.
  #100
Old 08-18-2022, 01:10 AM
ovzfz's Avatar
ovzfz
ovzfz is offline
MMI or Full NBT EVO retrofit
Do you know we're I can get a quote for the full NBT Evo retrofit here in US ?
Quick Reply: ID4 to ID5 Retrofit Completed (MINI F56 JCW ).... Happy Carplay User...
