Navigation & Audio Volume Limit on H/K Can we Change it?
Old Nov 30, 2004 | 06:09 PM
CustomAV's Avatar
CustomAV
Well it seems that when listening to my stock H/K system I have turned all the way up and then after a few minutes of driving, will forget this fact, and try and turn it up louder only to my frustration.
Is there a gain on the amp I can change or some trick anyone knows? I ask without looking only because I have the changer bolted in with a XM direct tuner and blitsafe adapter crammed into the space with the H/K amp and don't want to pull it out for no reason.
If there is even a wway to reprogram the stock Head Unit I would be game!
Please let me know.
Chris
Old Nov 30, 2004 | 06:24 PM
bodinski's Avatar
bodinski
Lowering the bass setting will get you more volume. I don't know of any other way..
Old Nov 30, 2004 | 06:26 PM
mini giant's Avatar
mini giant
bump because i would like to hear my music when the windows are down on the freeway
Old Nov 30, 2004 | 06:37 PM
CustomAV's Avatar
CustomAV
Even with the windows and roof closed I stilll have the music all the way up and there are times I just want to rock with the band.....
I have the bass actually down about 2 turns as it is since the system is sooooo bass heavy
Old Dec 1, 2004 | 06:24 AM
GBMINI's Avatar
GBMINI
The limit is not adjustable.
The source volume level is about the only thing you might be able to adjust - if you are playing home recorded CDRs you could see if you can increase the level (dB) without hitting a distortion level.
My system can theoretically put out the absolute maximum from the HK, because I can overdrive the inputs from my aftermarket HU - but I have never taken it to max because of the risk of damaging speakers.
Cutelildevil666
Sep 12, 2015 09:36 PM
sprp85
Aug 22, 2015 06:16 AM
FLYM1N1
Aug 16, 2015 01:17 PM
CARdiac
Aug 8, 2015 03:30 PM
