Navigation & Audio Base speaker swap for HK 6.5" driver
Old May 3, 2018 | 05:51 AM
kurtsunn's Avatar
kurtsunn
Does anyone know if the base stereo 6.5" driver can be replaced with the HK 6.5" driver - don't care too much about sonic quality, more concerned about it fitting physically and the connector working - just need to get a stereo back to working as a result of a blown speaker in the base stereo setup. There seem to be a lot more used HK units on eBay, etc. and they actually are generally LOWER in cost that the base replacement. Physically they look the same - 4 screws, same-looking connector. Looking for plug and play if possible.
Old May 3, 2018 | 07:28 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
The Ohm rating of the speakers are the determining factor. You might not care about sound quality, but you could damage head unit if the ohms are not a close enough match. Hopefully someone will chime in with the actual numbers for you. You might be better off just buying a pair of cheap 6.5" speakers to match what you have.
MassMini
Jun 21, 2017 12:45 PM
irishpunk
Tires, Wheels, & Brakes
15
Oct 22, 2011 09:02 AM
bradchatellier
12
Sep 27, 2007 05:54 AM
mininasser
Sep 14, 2007 02:36 PM
aVjai
Dec 8, 2002 09:14 AM
