Navigation & Audio XM Direct install for $150
#351
on
I'm just getting inon this, and hope this not too redundant, but a question or two.
1. Are all 2005 MINI cooper satelite radio ready?
If so I have located at Myradiostore.com a DIRECT RECIEVER ,XM-RVR-D-101 FOR 159.99 Is this a good price, or is there some cheaper and or better out there? No IPOD here, so I guess I don't need the blitzsafe? Right??
#352
You may find it cheaper, but not by much. The nice thing with this vendor is that you can return it up to 30 days no questions asked.
Oh, and 05 radios are Sat ready.
#354
Hi All,
I hope this isn't inappropriate in this forum, so here it goes...
I've have the XM Direct box and Blitzsafe adapter installed in my '06 MCS with H/K and Nav. The setup has been absolutely flawless and I couldn't have driven without it, however, my new '09 MCS is on the docks waiting for ride over to the 'states and has integrated Sirius.
As such, I'm wondering if anyone is insterested in making me an offer for the XM Direct box and Blitzsafe adapter? If it's worthwhile, I'll uninstall from my trade-in '06 before accepting delivery on the '09 and give it a great home in someone else's ride.
I also have a Parrot CK3200 color BT kit installed that I can remove and sell. The unit's audio passes through the car's speakers and mutes the stereo on a call, but does not integrate with the MFSW. It does, however, have a really nice color display with control buttons and allows for in-kit voice tagging and picture callerID even from an iPhone. (deets upon request). Nice kit, but my '09 MINI has integrated BT.
Anyway, if this is inappropriate in this forum, please excuse the post. If there is any interest in either kit (XM or BT), please let me know via PM or return posting here.
Thanks!
Thanks!
#356
#358
Contacted the people at MyRadioStore about what I should get so I had a starting point. I have a DICE unit for my iPod and either like to replace the DICE unit or just keep it working while installing XM.
The customer service person pointed me to this:
http://www.myradiostore.com/xm-radio...ni-cooper.html
Any idea if that's what I need or if I should get anything else? Thanks!
#359
This is most likely the best solution if you want something that looks OEM.
#360
That's what I have and it works perfectly with the XM Direct receiver. I also have a Dice (the one that connects at the CD changer cable). The Dice also plugs into the Blitzsafe and you select between XM and Ipod by pushing the mode button on the head unit. Everything can then be controlled by the MFSW buttons. The only drawback is that the information displayed from XM is limited to one line of 12 characters.
#361
The only tricky part was because I have HK, so the amp takes up space in that cubby hole area. Took me a few tries to figure out how to fit both boxes back in there, but it is possible.
#362
I put the antenna puck on the dash right at the windshield up front. I didn't want to scratch the paint which I have seen happen a lot on other cars with the magnetic antenna just stuck to the roof. Reception is fine most of the time that way. The one exception is if I am headed directly north and going downhill. Since the satellites are to the south, the angle in that situation blocks the antenna with the roof. Otherwise everything works great.
#363
#364
I just did this install today as well as a DICE iPod adapter. It was incredibly easy...except getting everything into the small space left by the HK amp. I know a couple of threads say they got it all in but I was not able to. I had to make a choice and ended up leaving the XMD unit in the boot compartment. The hatch still closed tight even with three wires coming out the side. I am now looking for a way to secure the XMD box to the side wall of the boot. Tried velcro but the adhesive side would not stick to the side wall of the boot at all. Open to suggestions there. End result is pretty awesome though. Great sound from XM and my iPod. Highly recommended. Tom at EAS (DICE adapter) was awesome help and the folks at myradio store had a great price on the Blitzsafe and XMD receiver unit.
squawSkiBum
10-02-2015 09:21 AM
