Navigation & Audio upgraded speakers
Layiyiyi. Thanks for the clarification.
I would guess that you get the Bravsound equivalent to the HK underseat subs. The problem that I have been told is that the HK amp would be tuned to play with the frequency response of the speakers the system comes with. So, without changing the amp the speaker change on the HK system is pretty pointless because even if the speakers are better the amp won't send them a "better" frequency response so they will likely sound the same.
Can't wait for you to get yours up and running!
All of this is to say, we aren't putting "HK" Bavsound woofers in the car. What we send is engineered to match the factory amplifier and audio system, and deliver significant improvement in bass response without requiring a change in amplifier.
This is achieved through the following key ways in the "Base" audio cars:
1) Much more speaker surface area -- if you compare the factory underseat woofer cone area to ours, it's roughly 28 square inches of cone area, whereas ours is roughly 50 square inches, since we are replacing a 6" woofer with an 8" woofer. That's a 56% increase in cone area, resulting in significantly more air movement, and thus, more bass response.
2) Much improved low frequency response -- our woofer is a hybrid mid and sub woofer, with nearly flat frequency response (+ or - 3dB) from 38Hz to roughly 200Hz. That means the missing "low end" in Base audio cars comes to life... because it's actually THERE. I can't recall the exact numbers off the top of my head, but the factory drivers drop off pretty quickly below 100Hz.
3) Better dynamic response for more natural, accurate bass. Our motor design and suspension is light years better than the factory woofer.
4) Much lower distortion due to a variety of design elements, but especially a significantly more rigid woofer cone due to use of higher quality materials.
I can go on and on, but those are the most important differences. Of course, as with everything we sell, you don't have to take my word for it. We offer a full, unconditional guarantee that you'll love the upgrades, and if you don't, send them back, used, for a full refund.
If you're still interested in the product, please contact me directly at mdc@bavsound.com so I can take care of you personally with a significant discount. Please note I'm one of the owners and it may take me a bit to respond if you send an email, but I promise I WILL take care of you.
Also, I know it's probably a bit late, but here's the installation video:
GregoryK, I researched the FOCAL speakers. It looked awesome but the prices were much higher than what my budget would allow. By the way I listened to the underseat woofers last night and the difference in sound quality is awesome thus far. You can now feel the base. I can only imagine that with the other speakers, which should arrive next week, that it will only get better.
Actually that's not exactly correct. Here's the key difference -- in each audio system type, there is a different amp, and the subs that operate on that amp are at a different impedance depending on the system (and have some significant mechanical and acoustical differences as well).
First I was told that they were shipping on last Friday. Then they were in a crate and where going to ship Monday.
I'll give a call tomorrow.
I finally received the door speakers to replace my base system. A couple of weeks ago I replaced the underseat woofer. I have installed the underseat and door speakers. The install was very, very easy. I also applied the sound deadening to the doors. The sound improvement is awesome. Tomorrow I will install the back ones. So far so great!!!!
Essentially the same but without the difference in cone size. The improvement in items 2 - 4 is less pronounced because the HK woofer is higher quality (not great, but less terrible) so the difference is smaller. There's still significantly more bass, but the biggest improvement is qualitative (the quality of bass) and much better low end extension.
Again, install is 90 minutes at most, and we have a full guarantee. Try them out -- if you don't absolutely love them, we'll take 'em right back, no questions asked.
Received the Bavsound speakers yesterday to replace the base speakers in my car. I won't comment on sound quality yet since they've only been in for about 20 minutes.
The speakers are worlds better quality wise when compared to the stock pair. Installation took about 1 hour from start to finish (front pair only). Very straight forward - I wouldn't hesitate to suggest people try this installation themselves, just make sure you have the proper tools as mentioned in the video posted, the non marring tools are an absolute MUST, those panels are on extremely tight.
I'll report back when I've had a chance to test them out a bit more, the real test will be seeing if my wife makes any comments, as she listens much more than I do.
I finally installed all speakers (underseat, front and rear). As for the installation, the underseat was the easiest install. It took an hour total for both. The front install took approximately 1.5 hours with sound deadening. There weren't any problems with that install other than making sure that your windows are down to make sure you don't scratch the window tinting upon reinstallation if you so have tinting. Following the video is the best bet.
Now for the back ones... That was a bit more difficult. I followed directions for the most part by removing the seat and like the gentleman in the video I broke the plastic part. I ordered a new one for $20 with no tax and free shipping from Turnermotorsport.com (Cover For Center Bearing - 52207348021). I tried every which way to remove it without breaking it to no avail.
As in the video I removed the top panels, but I only partially removed the side panels. Doing so allowed me to still be able to install the sound deadening. Maybe because i am petite and have little hands is the reason I was able to work comfortably in the back area. I imagined if I had "allowed" my husband to install it that he would not have fit back there comfortably. He would have definitely have to remove as in the video. Also making sure not to twist when removing the back seat is very important. I found that the hole where the seat connects will give and become deformed if not careful.
My box did not have the foam. I emailed and was told that it was under the speakers. Both boxes did not have the foam. So I went to home depot and bought window foam insulation strips. It was a perfect substitute.
The back speaker installation took about 2.5 hours. Ok, maybe 3.
Spent more time in the car this weekend since installing the new speakers, wife noticed the same stuff I did. The sound is definitely better, the bass is more pronounced and defined, same with the highs. All around it sounds much better than the standard stock system ever did. Has me really tempted to purchase the rest of the upgrades now.
I'm so sorry you weren't happy and that you didn't have the experience we promised. This is a new product launch for us and, unfortunately, we dropped the ball. We're not perfect, but we always make it right.
Bavsound Mini Stage 1 Audio Upgrade Installation - YouTube
No.
When I had to nag just to get a refund...
Again, really sorry you didn't have a stellar experience.
Just saying...
We do offer 0%, up to 12 month financing through Affirm. Not everyone qualifies, but if you have decent credit chances are good that you will.
Just saying...
Just saying...
I just recommended a guy on Reddit check out your stuff. He's really not happy with the lack of bass in his new F56.
