Navigation & Audio Best Fuse Slot for Sat. Radio
I am looking for a power source for my after market satellite radio. I have a fuse circuit tap and looking for the best fuse slot to tap into. Currently I am tapped into the 15A radio but I noticed the sat. radio does not cut off when I cut the car off. I realize this is because the Mini allows you to cut the radio on with out cutting the car on or turning the key to accessories. I know if the radio is left on with the key turned to off, the radio will turn off after a certain amount of time.
My question is, will the Mini kill power to the sat. radio too after a certain amount of time, since it is taps into the same fuse slot?
It's currently wired with the radio. Which is fine, but if I leave the sat. radio on will the car cut if off after awhile or will it run my battery dead?
Navigation & Audio HK Replacement With New Components
Filmy
15
Jun 6, 2023 06:27 AM
molala
Oct 2, 2015 01:53 PM
R50/53 What is up with my 2005 r53?
rustof
11
Sep 25, 2015 10:35 AM
WillShootPhotos
Sep 14, 2015 07:50 AM
