Navigation & Audio R58 hk rear speakers low
Old Jun 26, 2014 | 10:07 AM
cpelayo17's Avatar
cpelayo17
I adjusted all the settings, someone said the back speakers are fillers, is this true? Anyway to make them louder?
Old Jun 26, 2014 | 10:17 AM
Adjust the fader fro front to rear a bit. Amp is under the seat.
Here is another thread that to adjust the sound with the H/K system.
https://www.northamericanmotoring.co...r-phoenix.html
The speakers are in the back, four of them and two on each side.
There is some info:
http://www.mini.harmankardon.com/bro...coupe_2014.pdf
http://www.mini.harmankardon.com/en/...technical.aspx
Old Jun 26, 2014 | 10:46 AM
cpelayo17's Avatar
cpelayo17
I checked out the website but only has specs of the speakers
Old Jun 26, 2014 | 10:53 AM
Changing the fader and the tone is you best bet, also make sure the speed sensitive volume is turned up.
That shows you specs and locations above.
Old Jun 26, 2014 | 10:59 AM
cpelayo17's Avatar
cpelayo17
I'll check the sensitivity. Thank you
Mini'mon
Aug 26, 2015 01:02 PM
Aug 19, 2015 12:34 PM
Aug 19, 2015 12:33 PM
OutMotoring
Aug 6, 2015 09:32 AM
