Navigation & Audio 2012 R56 with HK system question
Old Nov 2, 2013 | 10:29 PM
Fugy's Avatar
Fugy
Hi, I have a 2012 R56 with the HK system. Would it be possible to use an aftermarket head unit with the stock HK amp and speakers. I know the Gen 1 minis had the HK enabler. Do they make it for Gen2 Minis? Thanks!
Old Nov 3, 2013 | 03:45 AM
docrc's Avatar
docrc
You can not take out/replace the head unit in 2nd gen MINIs without losing functionality of many things (display, steering wheel contols, gong, etc) because it is tied in with the CAN/BUS. Look thru the threads, double din is probably the best. When/if you go there you risk opening a big can of worms. If you do, please chronicle your adventure. We all wish it was not that complicated.
Old Nov 3, 2013 | 05:38 AM
Fugy's Avatar
Fugy
thanks for your reply! I did skim through the double din thread. I was thinking of piggybacking the new HU with the stock. Would I need to completely bypass the HK system, no way to "trick" HK system in powering the speakers with the new HU?
Old Nov 3, 2013 | 07:43 AM
docrc's Avatar
docrc
Look at Integral Audio's instructions for your MINI model. Does not go into replacement of the the head unit but gives a usefel runaround for great sound, to include addition of an amp, replacement of the door speakers and addiion of a sub in back. They have a complete package. Expensive, but you could spend as much in time trying to circumvent that headunit. IMO best left as is.
Old Nov 4, 2013 | 06:53 PM
richardsperry's Avatar
richardsperry
Like they said, anything is possibly if you throw enough money at it.
Just wondering what you are trying to accomplish by using an aftermarket hu?
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
FrostyFox
Oct 28, 2015 02:06 PM
jeffbeckhudd
Aug 29, 2015 09:11 PM
Aug 12, 2015 01:24 PM
