Navigation & Audio 2004 S stock alternator amperage?
Old Aug 21, 2012 | 07:41 AM
Lowerr's Avatar
Lowerr
Looking to install a monoblock into this but not too sure if the alternator can keep up. Hopefully it's a minimum of 90a.
Old Aug 21, 2012 | 12:53 PM
JumpingJackFlash's Avatar
JumpingJackFlash
All 1st-gen alternators are rated for 105 Amps. Should be plenty. I have a 250W amp and 300W. Headlights would dim just slightly if I crank it way up. Also have a 1 Farad capacitor installed. No issues.
Old Sep 3, 2012 | 11:09 AM
kl0wn's Avatar
kl0wn
What size monoblock? I am currently running an AQ2200 for the sub stage and a RF Prime 300.4 for the highs stage, with stock alt, stock battery, and a Kinetik 1400 in the back. I drop down into the mid/high 12's while idle.
Old Sep 9, 2012 | 02:09 AM
Lowerr's Avatar
Lowerr
AQ750, then probably an AQ120.4 later on. Nice to see another person using AQ product on a message board like this.
Old Sep 25, 2012 | 03:43 PM
kl0wn's Avatar
kl0wn
With those you'll be fine on the stock alt. I would recommend upgrading the stock battery to a Kinetik or XS Power.
If you do that though, go with something smaller than the Kinetik 1400, it is too high. After my post I ended up putting the 1400 in the stock location, and threw a 2400 where the 1400 was. But I had to build a false floor to fit the 1400 because it a lot taller than the stock one.
If you ever need help just send me a message. I don't check these forums often, so I can tell you easier ways to get ahold of me if you need.
Spank
11
Apr 9, 2020 02:23 PM
Dec 5, 2016 06:31 PM
Mini7
Feb 2, 2016 07:52 PM
gmonde
Sep 8, 2015 06:37 AM
RACEnSK8
Sep 1, 2015 09:33 AM
