Navigation & Audio Help with Sub install!
Old Feb 15, 2012 | 06:54 PM
itsmewutup's Avatar
itsmewutup
Ok, so I've searched threads, and Google for about 3 hours now and cannot find an answer. So I apologize if there is already a thread with my answer in it.
I just purchased a 2008 Mini Cooper S, it has a factory installed Amp in the back, but I would like to install 2 12" subs with an amp. I bought an in line output converter and was told to hook it up at the factory amp. The only problem I'm having is finding the wiring diagram for the amp harness. All I need is right/left rear speaker wires, and I can find my own ground for the converter. If anyone knows which wires coming from the amp are the correct ones, please let me know. As far as the rest of the wiring, I've already got ideas on how to run that but I am welcome to any suggestions
Old Feb 16, 2012 | 04:11 AM
yetti96's Avatar
yetti96
It would help if you post int he 2nd gen section or R56 as you have an '08 (unless it's a convertible, then 1st gen).
Research the X9331 connector. Simply taping into the rear speakers will not work as they have a cutoff at 100Hz, right where your subs should be pounding and lower.
Old Feb 16, 2012 | 05:08 AM
itsmewutup's Avatar
itsmewutup
Ok my bad, I'm still a bit of a n00b.
Thanks, I'll look into that
adrchn
Aug 13, 2019 02:11 AM
minimofo
Nov 5, 2015 08:40 AM
minimofo
Oct 25, 2015 05:53 PM
minimofo
Sep 9, 2015 10:29 AM
