Navigation & Audio Does the Standard System Have Thermal Protection Built In?
Old Oct 12, 2011 | 12:15 PM
aerodynamics's Avatar
aerodynamics
Or has the speed sensitive volume control gone bonkers?
Reason I ask is because the volume seems to drop at random, regardless of speed - highway or city. The only consistency I notice is that the volume drop usually happens after approx. 10 minutes of playback at high volumes. During this time the volume cannot be increased, only decreased. After about 5 minutes or so - I'm assuming a resting period - the volume returns to normal.
By the way, how do you turn off the volume control? At the time of purchase, the MA went through all the features and I knew this was something I'd want defeated but he said there was no such option, only to adjust its sensitivity from 1-5 (or something like that). However, the MINI site says "you can also turn it off whenever you like."
Old Oct 12, 2011 | 03:30 PM
strobeyprobey's Avatar
strobeyprobey
Yes there is thermal protection on both the head unit and the HK & HIFI amps. Sorry, no way to turn off the speed volume completely.
You may have a blown speaker or something creating decreased resistance, thus overheating the amplifier.
Old Oct 13, 2011 | 07:32 AM
schatzy62's Avatar
schatzy62
+1
But when my head unit overheated and went into thermal protection the sound went away completely. and when I overheated the HiFi amp it also cut all sound.
Now with that said it could be a speaker problem, where one or more is cutting out and that is causing the reduced sound output. Or you could have a loose wiring harness or a short in a harness somewhere that can cause this type of sound reduction but if it really comes back in a specific amount of time and is the same amount of time every time it does sound like a heat problem that is not part of the thermal protection system.
Old Oct 13, 2011 | 02:20 PM
strobeyprobey
That makes more sense to me, that the head and amp shut off completely for the thermal protection.
Old Oct 13, 2011 | 05:22 PM
aerodynamics
I should add that whenever this happens, it doesn't sound like speakers are cutting out. There is a definite roll-off in volume - albeit a significant one - that sounds like someone turned the volume **** really fast. All speakers continue to play just at much lower levels.
khumpert
Nov 30, 2015 11:48 AM
theblackfalcon
Oct 11, 2015 09:49 AM
Pyrs
R55 :: Clubman Talk (2008+)
19
Sep 8, 2015 01:43 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
