Navigation & Audio Question on Amp Installation
Old Sep 9, 2010 | 04:40 PM
Crabernacle's Avatar
Crabernacle
I finally ordered the last part of my audio upgrade, an Alpine PDX4.100 amp. Unfortunately I'm having a very hard time figuring out how to install it. Keep in mind this is a 2004 R50 with a basic non h/k stereo.
What I have installed:
Alpine IDA-X305 Headunit
What I have to install:
•(1) Pair Polk DB6501 Components
•(1) Pair Elemental Design e3.6 6.5" Subwoofers
My current plan is to mount the amp behind the right rear panel, where the factory H/K amp usually resides.
I know that I could probably get better sound running new speaker wire, but if I could avoid this step and just use the factory wiring I would prefer to go in that direction. I've been using This Build as reference, but I don't quite follow his explanation on how he utilized the stock wiring. If anyone could shed some light on this, I'd be greatly appreciative.
Old Sep 9, 2010 | 05:52 PM
DreamingTwig's Avatar
DreamingTwig
Hey there...
I've got an x305 too... You like it?
I just went through a major audio upgrade and have an Amp left over...
Alpine KTP-445 Power Pack
plug-and-play compact Class D amplifier for Alpine in-dash receivers
4-channel amplifier
45 watts RMS x 4 at 4 ohms (CEA-2006 compliant)
I put that under the dash under the glove box. The connection plugs right into the head unit. Easy. No cables to cut or run. Now it's on a shelf. I'll sell if you need?
What amp are you using? I bought a JL XD600/6 and mounted it under the driver's seat. There's a hole there that makes for a perfect fit with the top under a grate to let it breathe.
Old Sep 10, 2010 | 12:11 AM
Crabernacle
I love the IDA-X305, i don't use cd's and it integrates seamlessly with my iphone 3GS. I wish the color matched a little better, but I'll take function over form any day.
Thanks for the offer, but I've already ordered an Alpine PDX-4.100 amp. It's 4x100 rms, regardless if it's 4ohm or 2 ohm, plus it's tiny. Installing it under the seat is an option, but I was hoping to avoid having to cut up too much of the interior. Thats why I'd prefer to install it where the H/K amp usually is.
I did forget to mention that I already have a 12" sub with an 800 watt Pioneer mono amp. Would I need a distribution block if I need to power two separate amps?
adrchn
Aug 13, 2019 02:11 AM
silence2-38554
Nov 12, 2015 09:39 AM
squawSkiBum
Oct 2, 2015 09:21 AM
Lee-Oh_825
Aug 11, 2015 10:27 PM
