Navigation & Audio Garmin EcoRoute
Old Jun 14, 2011 | 02:43 PM
  #76
MiamiGuitarMan's Avatar
MiamiGuitarMan
Ok cool, just picked it up.
Now all I have to do is order the HD cable.
Old Jun 24, 2011 | 05:55 AM
  #77
Big Jim Swade's Avatar
Big Jim Swade
I just got my Garmin Nuvi 1390 with an Ecoroute HD and I have to say, theses are really cool. Having all the gauges with temp, voltage, boost pressure etc. feeds you a lot of information. After seeing the temp. though, I have to realized these cars do run hot. Mine is ususally running around 220F.
Old Jun 27, 2011 | 06:31 PM
  #78
TheCheatOSX's Avatar
TheCheatOSX
Got mine a few weeks ago too. So far so good with a few issues. It seems after a brief shutdown and restart of the car, the GPS goes into a charging state and doesn't come back on automatically like it used to. You have to hit the power button. I've also had some strange issues with the unit no longer speaking turn by turn, but messing with the volume seems to bring it back. I have the MINI branded Garmin Nuvi. Mine is also running around 220.
Old Jul 4, 2011 | 05:45 AM
  #79
rum4's Avatar
rum4
Just bought a 1450LMT yesterday and now I see that it isn't support on the list, damn. Wish I had read this before.....oh well
Old Aug 24, 2011 | 05:09 PM
  #80
u68423's Avatar
u68423
Just hooked this up to my new Garmin Nuvi 2360 LMT on my 2005 S I am in heaven with a craven speed mount the 5" clears everything (way to go) all works like a dream now on to a elect oil pressure guage and I am all set this thing even gives me direction @ the same time I see what my lump is doing,,,,,,,,,,,yes they run hot around 220. Now time to get the rest of my divorce devices put on...
Old Aug 26, 2011 | 01:13 PM
  #81
u68423's Avatar
u68423
connection
Have a 2005 s mine works fine
Originally Posted by MattEr76
That didn't do the trick either. Is anyone else here successfully installed one on a 1st Gen MINI?
Old Sep 1, 2011 | 09:51 AM
  #82
u68423's Avatar
u68423
My mount
Just a few pics, love this set up
Attached Thumbnails Garmin EcoRoute-img_0313.jpg   Garmin EcoRoute-img_0314.jpg   Garmin EcoRoute-img_0320.jpg
Old Sep 13, 2011 | 08:10 AM
  #83
Mindspin311's Avatar
Mindspin311
Is someone able to post a complete list of what parameters you can view on the gauges? Thanks!
Old Sep 13, 2011 | 08:17 AM
  #84
TheCheatOSX
I believe the info you seek is in this thread.
Old Sep 13, 2011 | 08:40 AM
  #85
Mindspin311
I wasnt sure if that was the only info available.
Old Sep 13, 2011 | 08:46 AM
  #86
u68423's Avatar
u68423
parameters
Here you go...... INTAKE AIR TEMP, THROTTLE POSITION, INTAKE MANIFOLD PRESSURE, COOLANT TEMP, VOLTAGE, SPEED, RPM, TIMING ADVANCE, ENGINE LOAD. I love this for the cost installing oil pressure guage. It also clears codes...
Old Nov 28, 2011 | 06:40 PM
  #87
Dodgy's Avatar
Dodgy
Blinking green light after MINI updated?
Hey, all--hoping to revive an old thread here. I had been using my Ecoroute HD very happily for several months. After my MINI was in the shop having the radio replaced (bad display), they also upgraded the firmware. This removed the trip odometer from the display, and also appears to have disabled my garmin's ability to connect.
Anyone else have the new firmware update who can still use the HD? Or are these two events unrelated and perhaps my ecoroute just died?
Thanks in advance!
Old Nov 29, 2011 | 05:50 AM
  #88
Big Jim Swade
Thanks in advance!
If you had the Ecoroute installed when the dealer upgraded the firmware, they would have had to unplug the Ecoroute. Did you check to see if it was plugged back in correctly? I don't see how a firmware upgrade would affect the Ecoroute's ability to connect.
Old Nov 29, 2011 | 07:18 AM
  #89
Dodgy's Avatar
Dodgy
Hi, Big Jim,
Yeah, if I had thought about it before taking the car in for service I would've completely unplugged it before dropping it off. I take it for granted and forget how the magic works!
But yeah, when I got the car back, it had been plugged back in. I've tried unplugging it, leaving it out for a few days, even holding down the reset button, but nothing. I might try it in my wife's car to see if it works there. According to the OBC, my first service is coming up soon, so I might ask the dealership, too.
Thanks for taking the time to reply!
Old Nov 29, 2011 | 03:46 PM
  #90
SpyVsSpy's Avatar
SpyVsSpy
I know it has to reconnect and I had issues with mine and selected disconnect and reconect from the Garmin menu. I know recently I did an online update to my Garmin 1490T and find that my HD drops out ever once and a while and I can't reconnect it. Might be an issue with the handsfree bluetooth connection with my iPhone interferring with the bluetooth HD, I do not know and it is frustating when I go to look at the guages only to find out they are not available.
Old Dec 22, 2011 | 03:23 PM
  #91
JPMM's Avatar
JPMM
so I have a Garmni OBD transmitter plugged into my OBD,now what?
The prevoius owner pulled the Garmin head unit out before he sold the car but left the OBD interface and the behind the tach mount. So what can I get thats cool?
Old Dec 23, 2011 | 02:02 AM
  #92
chaswyck's Avatar
chaswyck
Just get a Garmin GPS that's compatible with the ecoRoute. It will receive a signal from the OBD prompting you to set it up. I have the 1490 (5" screen) and I love it.
Old Dec 23, 2011 | 02:04 AM
  #93
chaswyck's Avatar
chaswyck
I understood that the ecoRoute also had the codex loaded into it so that when the car threw a code, it could read and interpret it. Is this true? Fortunately mine has not thrown a code yet so I don't know what the ecoRoute would do if it did and where I would find it.
Old Dec 23, 2011 | 03:39 AM
  #94
phoxx47's Avatar
phoxx47
I mounted the dongle with Velcro tape on the panel by the OBDII port. Easy to take off and switch to my F-250. Also very happy with the CravenSpeed mount for the GPS unit - attaches an arm to the back of the tach and allows concealing the power wires to the GPS. The power pickup is a spliced-in cigarette lighter socket that is within the center console - you use the Garmin supplied pwoer wire and can snake it up through the kick panel and out immediately beside the tach. With the Garmin power concealed in this manner you will need either to buy an additional one for another vehicle or just use a lighter socket USB to mini-USB from the aftermarket.
Old Dec 23, 2011 | 05:00 PM
  #95
JPMM's Avatar
JPMM
Garmin nuvi 1450 gps navigation system complete new
so this would work? by the way, will the interface work on my 2003 dodge cummins?
http://www.ebay.com/itm/150724131057...84.m1438.l2649
Old Dec 23, 2011 | 06:51 PM
  #96
MichaelinA2's Avatar
MichaelinA2
Works with these units...
https://buy.garmin.com/shop/shop.do?pID=38354
Cheers...
Old Dec 23, 2011 | 09:36 PM
  #97
chaswyck's Avatar
chaswyck
It definitely should. This model says it's compatible with ecoRoute.
Old Jan 30, 2012 | 09:24 PM
  #98
Dodgy's Avatar
Dodgy
I just wanted to follow-up on my earlier post where after my MINI's software was updated my GPS wasn't communicating with the HD unit. After trying lots of things, I did ultimately get it fixed by completely resetting the GPS to its factory settings. It's been a little buggy (my GPS has reset randomly, with decreasing frequency with each Garmin update, since day 1), but glad that it's all working again. I really like being able to see the boost, water temp, and timing advance.
Old May 23, 2012 | 11:14 PM
  #99
Summons's Avatar
Summons
I have a 3790LMT with the ecoRoute - love the setup, but does anyone know if it's possible to set what the default screen is? That is to say: if I power up the GPS, what screen it defaults to after a few minutes of inactivity? Currently, it goes over to the map - I'd rather it went over to the gauges...
Cheers,
E
Old Jun 4, 2012 | 05:55 AM
  #100
JPMM's Avatar
JPMM
don't think you'll find a way to reset it into that mode
Cheers,
E
