Navigation & Audio need help with speaker grill removal
Old Mar 23, 2010 | 07:09 PM
Paul984's Avatar
Paul984
Need help with removing speaker grill on door panel
Does anyone have any tips on removing the speaker grill? I tried
prying it off with a molding removal tool as shown an a pic that
someone else had posted but I can't seem to get it to budge. I think
I have already broken off the tabs holding it in place but it
still won't come off. Thanks.
Old Mar 24, 2010 | 03:21 AM
miniSQ's Avatar
miniSQ
there is a pin underneath that needs to be removed....
Old Mar 24, 2010 | 06:41 AM
SWorks's Avatar
SWorks
There isn't a pin on the speaker surround, that's on the door opener above
Try using your tool on the part behind the door handle bar, you will see where it joins and you can push your tool in there and it will just pop off.
It makes a loud noise and it sounds like you have broken the clips but you won't have done they are just strong clips that make a loud noise when they let go
Old Mar 24, 2010 | 06:06 PM
jgohlke's Avatar
jgohlke
You can try squeezing the cup a bit to loosen it. Be sure and get underneath the lip when you are prying. You can work your way around it too.
Good luck!
(that's my picture, btw)
Old Mar 24, 2010 | 06:36 PM
Paul984's Avatar
Paul984
Thanks Jgohlke. Sorry about borrowing your picture without permssion. I saved it to my computer and couldn't find the original thread where it came from. I finally did manage to get it off but broke off a tab in the process. Was a lot more difficult than it
looked.
Old Mar 25, 2010 | 05:31 PM
jgohlke's Avatar
jgohlke
Sorry to hear you broke a tab on the speaker cup. That's a bummer. No worries about the picture, hope it helped a bit.
cawwwtun
May 3, 2016 08:03 AM
jnrjr79
Navigation/Audio
18
Sep 18, 2015 05:51 AM
greekzilla
Aug 23, 2015 03:44 PM
