Navigation & Audio GPS Nuvi holder without visible wires
Old Jun 15, 2009 | 01:40 PM
stefspain's Avatar
stefspain
Does any one know a garmin nuvi gps holder that is fixed to the dashboard and which charges not only the gps but also links the nuvi to the antenna of the car (for capting the TMC channel) ? I do not want any visible wires !
Old Jun 15, 2009 | 07:05 PM
slimjimtell's Avatar
slimjimtell
The OEM garmin mount (from MINI) is a good mount that mounts over the steering column and all the wires are completely hidden. Although for your application, you can remove the OEM wire and replace it with your TMS cable.
Tap into the back of your CIG lighter and add a female CIG lighter behind the dash or tap into Fuse Box. You can buy one at radio shack with open wires for 6.99...
http://www.radioshack.com/product/in...ductId=2062272
This will give you the ability to plug in your TMS/Garmin cable behind the dash permanently and still capture the FM signal for the TMS.
Old Jun 16, 2009 | 01:16 PM
stefspain's Avatar
stefspain
Great ! Thanks !
Old Jun 16, 2009 | 01:23 PM
lacning74's Avatar
lacning74
in case it applies, i don't think the oem mount will work with wide screen Nuvi's.
Old Jun 16, 2009 | 02:21 PM
slimjimtell
Kuda Mont will work too.
http://www.kudausa.com/kuda_mount_an...07-34-529.html
Gominigo.com is indevelopment of an '07+ mount as well. This would be the best solution if it will fit Widescreen Garmins. For 30 bucks, i would say it would be the best. Contact them as to when the mount will be ready
http://gominigo.com/GMG-GPS-main.html
Old Jun 17, 2009 | 10:08 PM
GoMiniGo's Avatar
GoMiniGo
yes, the new mount will fit the widescreen Nuvi and the standard width versions as we have made it adjustable. Hope you guys will like it.
Timing, should be just a couple of weeks away as the shop is working on them now.
If you want to be one of the first ones out the door, contact us and you will be put on the interested party list.
Filmy
15
Jun 6, 2023 06:27 AM
shorenetworks
Nov 4, 2019 06:18 PM
Sep 11, 2015 01:15 PM
tylewis
Sep 6, 2015 07:36 PM
TREX
R58 :: Coupé Talk (2012+)
Sep 5, 2015 02:59 PM
