Navigation & Audio Help with installing SWI-X
Old Apr 10, 2009 | 02:59 PM
minijeremy's Avatar
minijeremy
Can anyone help me?
I bought the SWI-X adapter and went to go install it and wouldn't you know it, I can't locate the white w/ red strip and yellow dots wire. I've looked at every single wire over and over coming from just behind the steering wheel and I swear it's not there. Anyone else have this problem? Is there another wire I can try?
I have a 2003 JCW S.
Old Apr 11, 2009 | 09:12 AM
DanSeals's Avatar
DanSeals
This is where I cut and spliced. Had to trim back some of the wire wrap. The bundle above the steering column plastic. You can just see the wire peeking out. 04 MCS.
Old Apr 12, 2009 | 08:20 AM
minijeremy's Avatar
minijeremy
Found it, thanks. One more problem now....I got it all hooked up and when I turn it on, the lights just keep flashing. I followed the instructions and whenever I turn it on it just keeps flashing. Any thoughts or do I have a bad unit?
Old Apr 12, 2009 | 08:32 AM
DanSeals's Avatar
DanSeals
Just make sure the key is off. Press and hold the program button on the swi-x and then turn the key to the on position.
You cut the red/yellow dot wire, correct? You can't splice it you have to cut it then hook the swi-x to the wire that is coming from the steering wheel.
Other than that it's pretty much straight forward.
Dan
Old Apr 12, 2009 | 08:43 AM
DanSeals's Avatar
DanSeals
Man do I feel bad. I didn't pay attention to my pic and suggested the wrong wire earlier.
Make sure you got this wire. The one that is pulled down.
Old Apr 12, 2009 | 01:41 PM
minijeremy's Avatar
minijeremy
Attachment 41201
No worries. I did find the right wire. It was the white/red stripe and yellow dots. So I know it's hooked up properly, just doesn't seem to be functioning properly.
Old Apr 17, 2009 | 08:28 AM
paulieparker's Avatar
paulieparker
I have same issue with my SWI-X - I can program the first two and then the light goes crazy and nothing works...
adrchn
Aug 13, 2019 02:11 AM
minimofo
Nov 5, 2015 08:40 AM
minimofo
Oct 25, 2015 05:53 PM
minimofo
Sep 9, 2015 10:29 AM
