Navigation & Audio Speaker upgrade Hi-Fi - here's what I'm thinking
Old Jul 26, 2009 | 01:26 PM
  #26
Robin Casady's Avatar
Robin Casady
Originally Posted by paul_voorn
- I have a Clubman with HiFi (LoFi? It came pre-owned with Sat and HD Radio... they all sound like junk; zero bass and start distorting the minute you crank it up a touch)
- I'm looking for a cheap upgrade to move from a 'D' to a 'B-'... spending just $200 would be great.
- I want something that is braindead simple; no amps, no subs... just replace the existing speakers.
Q1 - Given that the Clubman's 6x9 is easier to replace (I think) than the regular Cooper, should I give that a go and see if it gets me happy enough?
This is one possibility. See if you get any bass from the rear speakers. Compare it to the bass from the lower speaker in the front door. On my 2007 the bass is cut off somewhere around 100-150 Hz. MINI may have changed this on more recent models. If the door gets more bass, you will need to do the channel swap at the X9331 connector under the dash. Search for the X9331 thread.
Q2 - Would you recommend OCS or go with Crutchfield (price premium but it seems that they cater to dummies like me a bit better, and I'm not sure if OCS is 'authorized')
I went with Crutchfield for my rear speakers because I wanted their tech support. However, they gave me incorrect info that really messed me up. Bought all the other speakers through Amazon for about half price.
Q3 - Did you go for the following speakers... and if so are you happy and on a scale of 1-10 how hard were they to install?
6020cs ? - 6.5" and separate 1" tweeter ($117 at OCS, $139 at Crutchfield)
4022i ? - 4" with built-in tweeter ($55 at OCS, $79 at Crutchfield)
9622i ? - 6x9" with built-in tweeter ($74 at OCS, discontinued on Crutchfield's site; is there a new version?)
I went with Infinity Kappas (HIFI 2ohm system on MINI) and find them to be a bit "bright." If I were doing it over, I'd pick a warmer speaker. Not sure which brand that would be, though.
Installation wasn't difficult. Had to drill an occasional screw hole, but you would with any speaker. Stock speakers have a very odd hole pattern for the lower door speaker. You also have to find a way to feed the wire from the front to the back of the speaker on the door. I poked a hole through a rubber plug and turned it into a grommet.
Old Jul 26, 2009 | 10:18 PM
  #27
paul_voorn's Avatar
paul_voorn
Hi Robin,
I had seen the x9331 thread before, but remember it saying 'this doesn't apply to HiFi systems', included making some weird 'molex'-like tool, made the bluetooth phone calls come from the back speakers and got generally very technical.... so on about 4 counts didn't sound good to me...should I re-think that?
I'll go listen to the bass in the morning.
So Crutchfield weren't all they were cracked up to be then?
paul
Old Jul 29, 2009 | 07:58 AM
  #28
paul_voorn's Avatar
paul_voorn
I just noticed someone else post that they installed
6022i speakers (6.5" but with integrated tweeter) $70@crutchfield...
And left the upper speakers disconnected (so as not to have 2 pairs of tweeters).
Seems like less money and an easier install.
I'm still puzzled why people aren't just doing a straight swap of speakers... i.e. snipping wires and replacing a 6.5" speaker with a 6.5" speaker (without tweeter), 4" with 4", 1" with 1" etc....
I'm probably going to wait until after vacation, see if I get some blindingly simple guidance (full video of speaker replacements anyone?, or better still someone telling me that if I JUST replace the rear 6x9s all will be much better and 'good enough')... and then I'll go for it.
Old Jul 29, 2009 | 08:27 AM
  #29
toolazyforalogin's Avatar
toolazyforalogin
IMO the 6x9 replacement was not worth the time nor $ I spent. Get a set of component speakers and do what you said by replacing the lower w/ a 6.5 the upper w/ a 4" and a 1" tweeter.
Old Jul 29, 2009 | 02:30 PM
  #30
Robin Casady
On my 2007 HIFI, the lower door speaker only gets bass. Putting a 2-way speaker there with tweeter would be pointless. That is why people use component speakers for that location, and put the separate tweeter elsewhere.
Nothing in life is simple.
Old Aug 1, 2009 | 08:14 AM
  #31
paul_voorn's Avatar
paul_voorn
getting close...!
OK... getting close... thanks to you guys for the responses...
Hey, TooLazy... did you end up installing the following items you listed?
I noticed that the 6020cs is listed on Crutchfield as 'does not fit'??? Does it?
Does one use the crossover that comes with the 6020cs to split out the tweeter or do you just ignore the crossover and rely on the OEM system and just wire in the 6.5" where the old one was and connect the tweeter where the tweeter was?
paul
Old Aug 1, 2009 | 10:41 AM
  #32
toolazyforalogin
paul
That's exactly what I did (and what most others did as well)
This is what I went with...all from amazon. Sounds much better now!
Infinity Kappa 60.9cs 6-1/2" component speaker system For 6-1/2" and 6-3/4" openings
Infinity Kappa 692.9i 6"x9" 2-way car speakers
Infinity Kappa 42.7I - Car speaker - 50 Watt - 2-way - 4"
Old Aug 2, 2009 | 07:08 AM
  #33
paul_voorn's Avatar
paul_voorn
Hi TooLazy...
Thanks for the exact specs...
I didn't quite get the answer to my question though (you said 'YES!' to an "A or B" question )
OR
Robin: you said the Kappas were a bit too 'bright'... I noticed on the Crutchfield web-site that it says "If you want 'brighter' sound..." upgrade from the 6020cs to the Kappas.
TooLazy...: the "tech at infinity" said if you're going to use the 'stock head' then go with the reference instead of the kappas... But in the end you went with the kappas.
So...with the benefit of hindsight... should I go with the Kappas or the Reference?
Old Aug 2, 2009 | 09:38 AM
  #34
toolazyforalogin
Hi TooLazy...
OR
Yeah I originally said to forget the crossovers and just replace the speakers but then somehow I edited that out! Sorry - and the techs at Infinity told me the same thing about the references since the RMS is lower but also said the kappas are a better sounding speaker and they would choose kappa.........whether is was b/c the kappas cost more I couldn't tell you but the prices difference wasn't that big (for me). Whatever you choose I'm sure you'll be happy as both the reference and kappas are great speakers.
woodstudio
Mar 15, 2020 08:28 AM
surfblue
Oct 24, 2018 01:20 AM
jnrjr79
Navigation/Audio
18
Sep 18, 2015 05:51 AM
