Navigation & Audio Confused about upgrading Hi-Fi speakers 2008
Old Nov 11, 2008 | 11:11 PM
LBMCS702's Avatar
LBMCS702
I have read thru a lot of the threads regarding this, but before I make any $$ decisions please give me some input.
I have the hifi lateral-grade stereo system.
First upgrade is to swap front speakers out.
I read the speakers are 2 ohm, most that I am finding online are 4ohm, which I also read work fine in the hifi system.
The speakers that I am finding( reasonably priced ) are mostly 2 way. If I swap out the 4" and the 6.5" and both are 2 way will this cause a problem?
Old Nov 11, 2008 | 11:23 PM
Robin Casady's Avatar
Robin Casady
For the 6" go for component speakers (separate tweeter). Use the tweeter in the A pillar. For the 4" I used a 2 way, but didn't connect the tweeter. For my ears, they would add too much high end to the system.
I used Infinity Kappas, which are 2 ohm. They are a bit bright in tone.
Old Nov 11, 2008 | 11:31 PM
LBMCS702's Avatar
LBMCS702
thanks for the reply Robin,
Looking at the 4" kappas I only see one input. How do you not hook up the tweets? Do you snip the wires coming up from the woofer?
Old Nov 12, 2008 | 07:39 AM
schatzy62's Avatar
schatzy62
There will be wires and a capacitor on the speaker as well all you have to do is disconnect the capacitor and that will disconnect the tweeter.
woodstudio
Mar 15, 2020 08:28 AM
Dec 5, 2016 06:31 PM
BRracing
Dec 22, 2015 09:25 AM
jnrjr79
Navigation/Audio
18
Sep 18, 2015 05:51 AM
Aug 21, 2015 11:18 AM
