Navigation & Audio Help - stereo lights up but no sound
Old Sep 28, 2008 | 11:53 AM
LH0121's Avatar
LH0121
Hi guys I'm hoping somebody can help? Just changed my speakers in my clubman, turned the stereo on and there is now no sound although the stereo lights up and works as usual.
I had turned the stereo on to check was working with every speaker and all was fine until I had almost finished (typical). My stereo is the standard boost system. could I have blown a fuse at the back of the stereo?
Old Sep 28, 2008 | 06:07 PM
k6rtm's Avatar
k6rtm
Oops...
As far as i know, the stereo itself doesn't have any fuses, just one in the panel by the passenger door.
That last step must have been the doozy -- did you short something out on the last speaker, or short a line to the chassis?
Old Sep 29, 2008 | 05:47 AM
schatzy62's Avatar
schatzy62
You are saying that you do not have the HiFi upgrade. In that case the radio system in the dash has the speaker amp in it. So it there is now sound ( not even a pop) then i would check the fuses in the panel int he passenger foot well. Not sure if the radio amp has its own fuse or not.
With out looking in the manual i think it might be fuse 21 but not totaly sure.
Old Sep 30, 2008 | 09:06 AM
Nimcosi's Avatar
Nimcosi
You sure mute is not on?
Only half joking...
woodstudio
Mar 15, 2020 08:28 AM
surfblue
Oct 24, 2018 01:20 AM
Herleman
Aug 16, 2015 06:41 PM
yashmack
Aug 15, 2015 03:11 PM
