Navigation & Audio Aux port install question
Is it possible to install the aux port without removing my euroshelf? The clips that hold the shelf on are messed up and the fewer times I need to go in there the better.
If I pull pull out the downtubes, can I pull out the radio far enough to do what needs to be done? I want to run the aux port down to the botoom of the center console.
Thanks!
Thanks!
Yes, you'll be able to pull the headunit completely out after dealing with the downtubes. In an '06, drop the downtubes after removing the side screws, then the tops can be spread apart to expose the headunit screws.
penguinhomey
38
Jul 7, 2019 09:24 PM
Navigation & Audio My 07 COOPER S has an mp3 jack STOCK!
surfblue
Oct 24, 2018 01:20 AM
squawSkiBum
Oct 2, 2015 09:21 AM
