Navigation & Audio Line Out Converter
Old Aug 17, 2008 | 09:08 AM
n_wong89's Avatar
n_wong89
Line Out Converter
What line out converters does everyone reccomend? I Stopped by a best buy the other day, they had a range from stinger fixed from $20cdn bucks to a peripheral at $80cdn.
Anyone know any good ones that are bang for buck. Produce good noise without any crap. Not afraid to purchase online either. Names and links would be helpful
Old Aug 17, 2008 | 10:14 AM
k6rtm's Avatar
k6rtm
What do you want it to do, just convert from speaker to line levels?
Or do you want filtering and summing, for running a sub?
Plenty available on eBay -- I picked up a cheepie (less than $20) designed for subwoofer use.
Old Aug 17, 2008 | 10:39 AM
n_wong89's Avatar
n_wong89
Pretty much just want to plug my wires into my amp lol. I just want some thump and bass in my car. I am hooking up the wires from the input of the front low speaker. Will a fixed cheepie line out converter do the job? Is there any problems with the cheepie ones that you know?
Old Aug 17, 2008 | 10:54 AM
k6rtm's Avatar
k6rtm
Here's the cheepie I got from Amazon:
http://www.amazon.com/gp/product/B0002BEWYM
I used it in a breadboard/test setup, and it worked. Doesn't have a lot of flexibility, with fixed turnover frequencies.
The actual sub package I installed is this one:
http://www.amazon.com/gp/product/B000OSZA44/
which has everything in one smallish box. Right now, I have it sitting up in the boot:
Old Aug 17, 2008 | 11:20 AM
rkw's Avatar
rkw
I would suggest simply choosing an amp that has speaker level inputs. Many amps have inputs for both line and speaker level.
Old Aug 17, 2008 | 06:45 PM
RilianMini's Avatar
RilianMini
I bought the converter from Best Buy for $25...works great!!! (Forgot the brand, but i think its owned by Rockford Fosgate)
Then I got home and found this one...$4.20
http://www.partsexpress.com/pe/showd...number=265-025
Its only reccommended for up to 15W, but according to the specs on the Sticky in this forum, that is exactally what the non Hi-Fi radio is putting out on all 4 channels...
Old Aug 17, 2008 | 06:55 PM
n_wong89's Avatar
n_wong89
oH OKAY THANKS! Shipping that $4 item to canada costs $15...cheapest haha. and then i have to wait. I might as well just go to best buy and get one up to 15 amps or the one you got.
Bestbuy seems to only carry ''Stinger'', ''Monster'', ''Peripheral'' as their audio accessories. But they only had line out converters in Stinger and Peripheral, peripheral being the one that is $80 cdn.
Ring any bells, or can u find that brand out?
Old Aug 17, 2008 | 07:31 PM
RilianMini's Avatar
RilianMini
The brand is "IE" or "installedge.com" [It is in fact a division of the Rockford Corporation]
Model# - IEC AULOC
http://www.installedge.com/products/...roduct_id=1108
Bought it at the Chattanooga, TN Best Buy 2 weeks ago...
I assume Best Buy may use different suppliers in different regions...
Old Aug 17, 2008 | 07:46 PM
bobj's Avatar
bobj
You may want to look at www.crutchfield.com
Old Aug 17, 2008 | 10:42 PM
matty125's Avatar
matty125
I bought a Sosche, its just a pain. I will be replacing it with an AMP that has line levels.
Old Aug 18, 2008 | 07:49 AM
pentavolvo's Avatar
pentavolvo
i always use the tsunami one circuitcity carries never an issue in many installs
Old Aug 18, 2008 | 03:26 PM
n_wong89's Avatar
n_wong89
Model# - IEC AULOC
How did it work for you?
Old Aug 18, 2008 | 06:15 PM
RilianMini's Avatar
RilianMini
Its working great for me!
It was very easy to install, and its been in for 2 weeks, and I've had NO problems.
It has 2 adjustment screws/***** on it, and I have actually yet to touch them...so I am sure if I take time to set it up...it will be even better!
Old Aug 24, 2008 | 10:27 AM
xtrmsnds's Avatar
xtrmsnds
Any of you guys hooked up a 4 channel for your front and rear speakers using LOC's ?
Old Aug 24, 2008 | 01:38 PM
k6rtm's Avatar
k6rtm
My sub is running off the front channels from the head (see the frequency response and swap threads for gory details). If I go to a 4 channel amp, I'll be running all 4 channels from just the 2 front channel head signals as they're the only ones with full fidelity.
Old Sep 12, 2008 | 07:28 PM
BXR's Avatar
BXR
Stinger SLOC, SLOC II, SALOC (SGN13).
http://www.hifisoundconnection.com/S...9946/SFV/30046
I used the SALOC (SGN13).
Old Sep 12, 2008 | 10:41 PM
rasputinj's Avatar
rasputinj
I would just get an amp that has line level inputs. Put that $20 towards the amp. I will be using an 4 channel Alpine amp that has line level inputs.
Old Sep 13, 2008 | 03:46 PM
Satsloader's Avatar
Satsloader
Actually, if you want to run the HU's output directly into the front end of an amp you'd need an amp that can accept speaker level inputs, line level is "pre-amp" level..
I wanted to have some processing options ( EQ, 24dB crossovers ), so I got an Audiocontrol DQL-8 to use as my converter ahead of my amplifiers. It's EQ options are unmatched, but it's very expensive..
To run the HU's output directly into a four channel amp to power separates up front ( disregarding for the moment the rear fill speakers and any sub you might want to add as well ), you would need an amp that not only would have to accept speaker level inputs, but also have a hi-pass and low-pass crossover built into it. If you want to run a sub as well you should have the mid/midbass woofer bandpassed. You won't find a lot of four channel amps that offer both a hi-pass crossover and ( in addition to ) a bandpass crossover. This is where a processor ahead of the amp(s) can provide solutions. Keep in mind, you have to do some homework.. For instance, that DQL-8 I mentioned doesn't do bandpass. That's not a problem for me as my Zed Draconia amp does. The combination of the processor and amp ( both having the same order type of crossovers ) gives me a lot of flexibility.
BTW, to get hi-pass/bandpass capabilities out of an outboard crossover/processor, you'd want to look for a "Three-way" crossover capability.
I Hope that's a bit clearer than mud..
Cheers,
Bill
Old Sep 13, 2008 | 03:56 PM
Satsloader's Avatar
Satsloader
Found some mud
Regarding the bandpass, etc., my bit above was assuming someone was going to go active for the front speakers, splitting the hi/mid frequencies between tweeters and mid woofers via an active, or electronic crossover. Obviously the above reply would not be accurate for someone using components up front that utilized passive crossovers..
The bit about the speaker level output of the HU remains true..
Bill in P.G.
Old Jul 12, 2009 | 02:23 PM
juchong's Avatar
juchong
Question, where did you place the DQL-8?
techgearpro
Jul 23, 2019 07:09 PM
molala
Oct 2, 2015 01:53 PM
BucksCountyR57
R57 :: Cabrio Talk (2009+)
Sep 21, 2015 05:42 AM
Sep 4, 2015 09:23 AM
zr0z
Sep 3, 2015 04:50 PM
