Navigation & Audio sirius stratus sat radio install with custom bracket
Here's my Sirius Stratus satellite radio install. I used a pliable mounting bracket I had for another toy and just bent it into a L shape and double-sided taped it just above the key-slot trim and below the dash trim piece. I tucked away the cables behind the steering column/knee dash-trim. Easy to see, but a little difficult to use the buttons on the left. I connected it to the aux port and for now am using the external antenna mounted on the dash. I'm waiting for the cable to connect it to the car's built-in roof antenna as accessed under the passenger seat. The audio line output from the Stratus is weak, though. At max, it is only about 60% of the radio/CD. I'm probably going to upgrade to a fancy Sportster unit anyway since I'm definitely getting hooked on satellite radio.
When driving, easy to operate the buttons on the right (like the channel up/down ones), but not so easy to hit the ones on the left hand side (like preset buttons 1-4).
squawSkiBum
Oct 2, 2015 09:21 AM
