Navigation & Audio Best Speakers
Old Jul 24, 2008 | 07:02 PM
  #26
SomethingNew71's Avatar
SomethingNew71
Originally Posted by cmr076
the JL shallow mount subs were just released (which means there is not much feedback on them yet). a great setup would be JL c5 components in the front and 8" shallow mount subs in the rear factory speaker location (pioneer makes a great, cheap shallow mount sub.) i have done systems in quite a few mini's and always do something along those lines, with happy customers to say the least.
as we all know the "boot" of a mini is TINY and becomes useless when filled with sub boxes... if your concerned with space, the 8's in the back factory location are PERFECT and most 8 inch subs can preform "open air" (without a sealed box.)
i work in a high end car audio shop, and get hands on time with a LOT of brands, from TMA, to dyneaudio and even Mcintosh
My Opinion's, having owned or had time with all of the below
MB quartz = really really bright speakers, so if your into super high high's they may be a good choice.
focal = super nice all around speakers, but also are $$$
Dyneaudio = my favorite, and can be found cheap-ish online
diamond audio = poor quality, poor sounding and easily blown out (unless you do go with the HEX series, but they are $$$)
JL = one of the best car audio companies, with gear that can take serious abuse.
Infinity = i hated them, and swapped them out after 3 days. were not clean sounding, the build quality seemed cheap as well.
polk = *see infinity
***all of the above are my own personal opinions, please dont be offended if you disagree, i am just trying to give the OP some angles to take in**
This sounds all fine and nice but I have some questions....
1. Wouldn't that be a great deal of bass in the back seat. I often have friends ride with me and I don't want to blow their ear drums out.
2. Wouldn't that take away a good deal of mid-range sound from the system?
3. Would I need a separate amp for those little 8 inchers?
Old Jul 24, 2008 | 07:07 PM
  #27
cmr076's Avatar
cmr076
1. you fit people in the back seat?!?!?
2. depending on the front speakers they will more then compensate for the lack of rears... the mini is small enough that a really nice pair of fronts (with proper amplification) would do that.
3. either way if your adding a sub, you will need another amp (unless you go with a 5 channel amp.
Old Jul 24, 2008 | 07:16 PM
  #28
thbugman's Avatar
thbugman
Guys, i have an '08 clubbie with the hifi. I too want to have a system installed. Looking to spend a few more dollars though. Would i be better off going with a 2-way component set or a 3 way? Was thinking the CDT's sound great. Also thinking of a 10" sub, glassed box in the wheelwell. The new JL HD amps, look like they have a great imprint. Next ? keeping the stock headunit do i need something like JL's Cleansweep?
Old Jul 24, 2008 | 07:23 PM
  #29
cmr076's Avatar
cmr076
^^ cleansweep will work, MTX reQ is nice, audiocontrol also makes some good stuff (lc6 is my fav.) or just a plain ol' LOC would suffice i suppose
Old Jul 24, 2008 | 07:42 PM
  #30
SomethingNew71
Could I just stick those 8 inch subs in the trunk where the tool set is? Then replace all the speakers with speakers that would work with the stock amp? Or do I really need to get a new amp for the speakers too. If I need to get an amp for the speakers would I need a 4 channel amp for all those speakers or would I need to get more than one amp? Any info on those JL HD subs? Are the ZR series the best speakers the have?
Old Jul 24, 2008 | 08:03 PM
  #31
cmr076's Avatar
cmr076
if you want to keep your factory amp, you need to make sure the new speakers are the same impedance as the old ones... and yes, one four channel amp would work for your four interior speakers unless you want to bi-amp the fronts (give the tweeters there own channel) but if you do decide to go bi-amping your entering into an entire new league so to say!
the JL HD is there new line of amps, there is a 600/4 and a 750/1 both are relatively expensive, but nice amps.
the ZR's are JLs highest end speaker and are worth every penny IMO.
Old Jul 24, 2008 | 08:41 PM
  #32
SomethingNew71
Well I have the Hifi sound system. So ten speakers.... I looked online although I am not understanding which speakers I will need. Could you help out. I am very ambivalent to trust sound people at like tweeter to tell me the right thing.
Also I just looked at the price of the ZR's, although they may be worth every penny. I do not have every penny. The C5's look like what I could pay for.
Old Jul 24, 2008 | 09:54 PM
  #33
mslatter's Avatar
mslatter
OK, good! You'd be in trouble if you're home system was based on a pair of Alexandria X-2's. You might be satisfied with the HiFi, and if not, you might be satisfied with an affordable speaker replacement. Sounds like JL Audio is a great selection, and you can move forward or backward from there based on your budget.
Old Jul 25, 2008 | 05:58 AM
  #34
cmr076's Avatar
cmr076
your speaker sizes are as follows:
Location_______Size__Depth
Front Speaker___6.5___3.5
Front Speaker____2____1.5
Front Tweeter____1_____2
Rear Speaker___6X9___3.5
Rear Tweeter____1_____1
you could do a 3 way set in the front and a 2 way set in the rear, 3 way speaker sets tend to be $$ and a really good pair of 2 ways (like the c5's) in the front would be more than enough (even though you would be losing two speakers [the 2" mid bass drivers] the difference between your factory installed and the C5's is HUGE)
Filmy
15
Jun 6, 2023 06:27 AM
RobbyD
Jan 29, 2019 01:22 PM
gar56
Nov 15, 2016 06:41 AM
vulkandino
Oct 31, 2015 08:29 PM
patsum
Oct 1, 2015 06:33 AM
