Navigation & Audio Stereo Automatically Turns Off
Old Jul 18, 2008 | 09:20 PM
dhoosee's Avatar
dhoosee
I want to wash my car.
I turn on the (Hi-Fi) radio to listen to the ball game.
15 or so minutes later, the stereo automatically turns itself off.
I jump back in, turn on the radio again....and....same thing AGAIN 15 minutes later!
What gives?
I've tried leaving the key in, leaving the doors open, and turning on auxillary power, leaving the key out, closing the doors but leaving the windows open, etc.....but all to no avail.
Does anyone know how to keep the radio on until the user decides to turn it off? I checked the radio and standard manual, and no mention is made of this "feature". I imagine that MINI installed it to save battery juice in case the radio is left on inadvertently.
BTW, I have the Convenience package with keyless access......
Old Jul 18, 2008 | 09:33 PM
bobj's Avatar
bobj
Yes its made to turn off to save the battery.
I had the same issue. I solved it by using a bigger sponge.
Old Jul 18, 2008 | 09:35 PM
dhoosee's Avatar
dhoosee
Originally Posted by bobj
Yes its made to turn off to save battery.
Is "use a bigger sponge" an option?
Yeah....to soak it with water and whip it at the head unit.....
BTW, your signature artwork is HILARIOUS! Well done!
Old Jul 18, 2008 | 09:53 PM
Oxybluecoop's Avatar
Oxybluecoop
Put the fob in and press the start button.Good to go.
Old Jul 19, 2008 | 09:17 AM
dhoosee's Avatar
dhoosee
Thanks, Oxyblue. I'll give it a try and report back.
By the way, SWEET 928 you've got there.....
Old Jul 20, 2008 | 12:57 AM
amazingrando's Avatar
amazingrando
Auto on Sport Button guy
Yep, that should work. I sat through a double feature at the drive in.
Old Jul 20, 2008 | 04:36 AM
glangford's Avatar
glangford
Won't the ignition actually be sending spark to the plugs when turning on the ignition? Should you sit there for any length of time that way?
Old Jul 30, 2008 | 12:14 PM
condor27596's Avatar
condor27596
Unlock the doors the normal way.
(I don't have comfort access)
Open the passenger door.
Do not open the driver door.
Insert key fob.
Radio should stay on a long time.
09R56
Nov 16, 2022 10:49 AM
khumpert
Nov 30, 2015 11:48 AM
Aug 19, 2015 08:28 AM
yashmack
Aug 15, 2015 03:11 PM
