Navigation & Audio Amp Replacement
Old Jan 2, 2008 | 07:19 PM
KShaub103's Avatar
KShaub103
Amp Replacement
Could i see some people picture of the amps in your R56
I need some ideas for my install
Old Jan 2, 2008 | 10:01 PM
Mach V Dan's Avatar
Mach V Dan
Stuffed mine into the little tool/jack well:
--Dan
Mach V
Old Jan 3, 2008 | 07:52 AM
kookmyers's Avatar
kookmyers
Under the drivers seat. (theres quite a bit of room under there when you cut the carpet....depending on what options you have)
if you dont have DSC, the passenger side will work just as well.
Old Jan 3, 2008 | 10:26 AM
Robin Casady's Avatar
Robin Casady
If you are starting from the HIFI system, be aware that the HIFI amp needs to be in the system for the dealer to upgrade software for the OBC. One person who replaced his HIFI amp reported here that the dealer would not upgrade his software to fix a DSC fault because the software upgrade needed to see all components of the system.
Old Jan 3, 2008 | 02:32 PM
KShaub103's Avatar
KShaub103
Ok has there be any problems with the bacis sound package
eliseo1981
Jan 28, 2021 02:45 PM
woodstudio
Mar 15, 2020 08:28 AM
SunnySideUp
11
Aug 26, 2015 06:42 AM
Lee-Oh_825
Aug 11, 2015 10:27 PM
CARdiac
Aug 8, 2015 03:30 PM
