Navigation & Audio Aux Input installed! (pics)
Old 03-28-2014, 03:46 PM
cbbarrentine's Avatar
cbbarrentine
cbbarrentine is offline
I don't know either like I said my 06 works fine but my 04 doesn't only difference is the Harmon kardon radio thought that might be it. It doesn't matter what type phone either I have plugged android phones in it and it doesn't work I have tried iPhone 4 and 5 doesn't matter
  #177
Old 03-29-2014, 11:48 PM
joylove's Avatar
joylove
joylove is offline
You need a GND loop isolator or to GND the cig lighter at the radio.
  #178
Old 03-30-2014, 08:25 AM
Mynewt's Avatar
Mynewt
Mynewt is offline
When I posted to this thread a while back, I didn't include pictures of mine which I chose to mount down on the console next to the mirror controls. (where the heated seat switches would be if I had them).
This is a really good location I find since my phone, which I use for podcast, lust sits on the passenger seat, this jack location is short, simple and out of the way; the cable doesn't have to run up by the shifter as it would if I put it in the switch bank. I don't even know how the cable would run if I mounted the jack in the gloe box; that would seem kinda' awkward.
This location was easy to run. Just had to take up the center console.
Yep. i had to get one of these too. Just do a search for "ground loop isolator" and you should find a bunch for $6 to $12.
Attached Thumbnails Aux Input installed! (pics)-aaux-20close-201_wblg.jpg   Aux Input installed! (pics)-aaux-20close-203_wblg.jpg
  #179
Old 04-02-2014, 10:37 PM
chdrake2002's Avatar
chdrake2002
chdrake2002 is offline
Help...
Originally Posted by Eric_Rowland
Depends on the date of manufacture of your head unit. If it's 2003 or later, it should work. You won't get the 'Aux' mode on the display until you have the aux-in plugged into the back.
Ok I purchased the cable and easily plugged it into the radio however I do not get the aux option. I pulled the radio out to make sure I had a good connection, but nothing changed. Any suggestions?
05 MC cabrio with HK
  #180
Old 04-03-2014, 02:34 AM
bavmotors's Avatar
bavmotors
bavmotors is offline
I actually got the aux option on my screen prior to the install
  #181
Old 04-03-2014, 04:47 AM
jt350's Avatar
jt350
jt350 is offline
Pushing mode button each time on radio should cycle thru from radio to cd to aux.
  #182
Old 04-03-2014, 06:04 AM
cbbarrentine
U have to have something plugged in to the aux cable or aux won't show up on your display with the hk
  #183
Old 04-03-2014, 06:42 AM
minibx's Avatar
minibx
minibx is offline
Yeah.... I don't think that's accurate. I have an 05 with the AUX input and it shows AUX on the HK head unit regardless.
  #184
Old 04-03-2014, 07:02 AM
cbbarrentine
I have an 04 MCS with hk and aux doesn't display unless something is physically plugged in
  #185
Old 04-03-2014, 07:19 AM
Eric_Rowland's Avatar
Eric_Rowland
Eric_Rowland is offline
Huh. Not my experience. Prior to using my Aux-in, I used it as a defacto mute button by scrolling to it.
Not sure what to tell chdrake. I think the GLI only affects charging, but it might be worth a shot.
  #186
Old 04-03-2014, 08:42 AM
joylove's Avatar
joylove
joylove is offline
1) Unplug your device from the cigarette charger
2) Plug in the aux audio
The Aux won't appear until it detect the impedance of the audio player at the aux port. This detection can be disrupted by the GND potential difference between the radio and the cigarette lighter when charging.
  #187
Old 04-03-2014, 06:29 PM
chdrake2002
Still no luck for me. I have tried my iphone and ipad. I have not use the power adaptor at all. Just running off their own power.
Thanks for the suggestions!
  #188
Old 04-03-2014, 10:03 PM
joylove's Avatar
joylove
joylove is offline
take some time to double and triple check your wiring behind the radio.
  #189
Old 04-04-2014, 12:28 AM
Eric_Rowland
Did you double check the MFG date of the head unit? Could have been swapped out for some reason. Also - no Nav, right? That requires some pin changes.
If nothing else, I can get you a known working combo for relatively cheap.
  #190
Old 04-04-2014, 04:44 PM
chdrake2002
I thought about that I had put it all back together...
No navigation.
Do I need to add a ground loop isolator? I've looked for one at several Radio Shack's with no luck. Saw some cheap ones online, but I don't want to be to cheap.
Thanks again.
  #191
Old 04-04-2014, 04:46 PM
joylove's Avatar
joylove
joylove is offline
Get the aux in working first before getting mixed up with ground loop isolators.
Can you post a clear photo of your wiring behind the HU?
  #192
Old 04-06-2014, 05:53 PM
chdrake2002
Radio pics
Got a chance to take some pics.
The part # is 65.12-6 961 275
Manufactured 05 February
Thanks again.
Attached Thumbnails Aux Input installed! (pics)-05mcradio.jpg   Aux Input installed! (pics)-05mcradio2.jpg
  #193
Old 04-08-2014, 07:48 PM
Eric_Rowland
Harumph. Unfortunately the best way to confirm is to take your aux-in and plug it into another HU with a known working aux-in. If it doesn't work, you know the aux-in is somehow faulty. The reverse (plugging that aux-in into your head unit) would also apply.
Where are you located?
I can send you a known good aux-in, but if it's the HU, then you'd need to replace that next. I hate unexpected results!
  #194
Old 04-11-2014, 04:08 PM
chdrake2002
I live in Lexington, NC.
  #195
Old 04-12-2014, 12:33 AM
Eric_Rowland
A long way from SC, CA (Santa Cruz, California) unfortunately. :(
  #196
Old 05-16-2014, 03:13 PM
KevinChristman's Avatar
KevinChristman
KevinChristman is offline
I just bought a 2006 R53. The previous owner had Mini install the "MINI Hands Free System with Bluetooth Wireless Technology" (this: http://motoringfile.com/howto/offici..._bluetooth.pdf).
My question is can I still install the Aux input with that in place? Or would I have to remove the bluetooth to install the Aux?
Thanks!
  #197
Old 05-16-2014, 03:21 PM
joylove's Avatar
joylove
joylove is offline
Yes.
No.
  #198
Old 05-16-2014, 03:24 PM
KevinChristman
Yes.No.
Awesome. Thanks so much for the quick reply!
  #199
Old 07-20-2014, 10:41 AM
rolla's Avatar
rolla
rolla is offline
Originally Posted by MINIDean
Something very interesting...I have an 03' MCS, February 03' build with Navigation and H/K. My car did NOT have the existing connector in the "empty" slot like everyone else with NAV. My AUX connector plugged right in and works fine. My NAV works fine too. Same mute function when directions are given.
Does anyone know why my car does not have this connector, but the other ones do? Very strange...
OK, after thinking about it, I don't think I have these connectors here because I have the H/K system. My mute signal is probably sent to the H/K amp instead. That's where those two wires are. :smile:
_________________
Stewy was born on 2/20/03, Current Status: I picked him up today, 4-1-03!! MCS, DS/BL, Prem, Sport, Cold, Harman Kardon, Nav, PDC, Rain Sensing Wipers/Auto-Dimming Mirror, Black Panther Leather with Anthracite trim!
Does this hold true for minis with HK and NAVI? I want to install the aux kit, but would like to know if other owners with the same specs experienced this as well before I start the work...thanks in advance.
  #200
Old 07-20-2014, 10:55 AM
scottie10014's Avatar
scottie10014
scottie10014 is offline
I had HK and navi, and I took the aux kit and removed the wires from the black plug and plugged them into spare slots in the black plug attached to the nav, etc. Kind of hard to explain and I think someone has already done a better job of covering how to combo both sets of wires (no splicing req'd) into one black plug. Everything works together and so far I've never had a problem with HK, navi or aux working together.
Quick Reply: Navigation & Audio Aux Input installed! (pics)
