Navigation & Audio Auxiliary sound not working on passenger side
Hello,
I just installed the auxiliary plug for the mini cooper, it was increidbly easy and just popped right in, but today I noticed theres no sound coming from the passenger side speakers. Its not the speakers because they work with the radio and cds just not on aux. should I unplug and replug it in or what else? Thanks!
Unplug/replug is one thing to try, but also make sure that your cable is stereo, not mono. Check by looking at the plug. I posted this a while back:
A stereo plug has 3 segments.
A mono plug only has two segments.
A mono cable should produce the same sound from both speakers, it should not cause no sound on one side.
I suspect that the problem is most likely either the cable is not properly connected, it's a faulty cable, or that the Aux Input needs to be checked right up to the head unit. It's possible one of the wires came loose from the connector.
Look at the diagrams of the plugs. The right side becomes grounded.
I have seen mono-to-stereo wires that do achieve same audio on both channels though, and that's probably why I was confused.
Kimolaoha
Jul 5, 2023 01:04 PM
Interior/Exterior Need Help With Exterior Decisions (05' MCS PHM/W)
boostedhaze
Jan 2, 2018 07:26 PM
cm.d
Aug 19, 2015 08:51 AM
quality_sound
Aug 7, 2015 09:36 AM
