Navigation & Audio Can you change the way street names are displayed?
Yep, that MUST be it. There is nothing in the manual on "how to display street names", becuase there is no such option. They are always displayed when you are zoomed in, in "Map direction of Travel". And I LOVE saying "Map Perspective" or "Map Direction of Travel" and watching the screen change. Voice command is pretty cool.
I believe there are different ways to view the NAV. IIRC, you can have the map full screen, or you can have a split screen where the other part has a directional arrow with the name of the upcoming street in fairly large type. I use the spit screen and don't have any trouble reading the street.
Just got my Sept build R56 with Nav and am having some real heart burn with this as well. One thing I noticed that helps a tiny bit, and you have to dangerously take your eyes off the road in order to see, but there is a small black dot associated with each road name on the applicable road (line). It is usually next to the first or the last letter of the name. Not easy to see, but it seems to help in the less cluttered displays.
The nav in the 1st gen MINIs can be in split screen mode all the time. However, I do believe that in the 2nd gen MINIs, split screen mode can only be obtained while a route is active (as you've mentioned).
Indeed, the small black dots are really hard to see in real life as well. It would be nice if MINI would change them to a more visible color and/or make them bigger. They do indeed help though.
Thanks, Chris G. for the spot-on info. Sure enough that's all it took to display the street names. Can't see the little black dots, but just seeing the names is better than nothing. And I really get a kick out of telling the nav unit what to do, too! Wish others in my life listened that well!
Lschneider
Aug 21, 2015 02:21 AM
