Navigation & Audio Parrot Bluetooth with 2004 MCS
my apologies if this topic has an answer somewhere, but I didn't a search and I can't find an answer..
I want to get a Parrot Bluetooth car kit for my 2004 MCS with an HK & Nav. The 04 does not have a MFSW.
My question is will the Parrot CK3000 Evolution work with my headunit? Will the phone info display when I'm making/Receiving a call?
Do I need a separate harness to connect the Parrot? Where can I get one in the US?
I want to know about the display reading because it will determine if I get the Evolution or the Parrot 3200 LS-Color.
Thanks,
MiniGEE
Thanks,
MiniGEE
You might check out this website! The owner can answer any question you may have and he is excellent to deal with.
http://www.newministuff.com/new/shop...roducts&cat=10
Jason
Jason
I have the kit from Mikey and it is a good kit. Here is the deal.
1. It does mute the radio when a call comes in and integrates with the factory radio (HK as well).
2. It will use the steering wheel if you get the module from Mikey.
3. It is voice activated (you simply press the phone button and it will ask you the name of the person you want to call).
4. It does NOT display any names on the NAV or radio. If you want that, you have to spend the 900 bucks on the EAS solution or the 1200 on the BMW solution.
Installation is a snap as Mikey includes all connectors. No splicing is required.
Spank
11
Apr 9, 2020 02:23 PM
mxr662
Aug 31, 2015 02:50 PM
Mr Wiggles
Aug 18, 2015 07:14 PM
