MTH Discussion (Archive) Have or interested in MTH software upgrades for your MINI? This is the place! Sponsored by MTH.
Throttle body
Old Jul 12, 2006 | 02:01 PM
MINI on the road's Avatar
MINI on the road
Throttle body
Is there a difference in size between the throttle body of an One and a Cooper?
I can take over a throttle body of a friend, he has Cooper.
Old Jul 13, 2006 | 04:30 AM
minti's Avatar
minti
They should be the same. Only MCS is bigger (in size and bore diameter).
Old Aug 11, 2006 | 02:16 AM
MINI on the road
Ok thanx!
I had send the question to more persons and they say all the same...
Now I'm thinking to install a M7 58mm throttle body in my One (2005), has this sense?
Old Aug 11, 2006 | 05:33 AM
DarkMiniCooperS's Avatar
DarkMiniCooperS
If you really want it, go for it...
BUT, I've read so many stories about it... From rough idle to check engne light to Limp-mode...
I'd put that $$$ on other parts. Do you have a rear swaybar? It is simply the top 3 mods to do on a MINI. Good brake pads, stainless steel lines, discs?
My 2cents.
Old Aug 11, 2006 | 09:48 AM
MINI on the road
When I install the throttle body, I'll do also a remap of my ECU.
I've no rear swaybar, it isn't installble because there are no brackets. The whole subframe should be change.
Old Sep 21, 2006 | 10:49 AM
Bahamabart's Avatar
Bahamabart
My 2cents.
I agree - I would start elsewhere
Old Oct 2, 2006 | 12:15 PM
TUFFMINI's Avatar
TUFFMINI
M7 Tb
I have the MTH Header with the MTH stage 1 tuner file, i still get the EML light comes on. anyone have this issue?
the manual for the MINI states take to dealer but with the tuner file loaded they may say that is the issue. however the issue started when i swapped to the M7 Throttle Body. when i place my stock TB on the issue goes away...
Any suggestions other than keep the stock TB on?
thanks,
Kev
bahman
Feb 14, 2016 10:29 AM
wildwestrider
11
Jan 29, 2016 05:06 PM
Qik420
Oct 4, 2015 08:19 PM
Qik420
Oct 1, 2015 12:02 PM
Emnotek
Sep 29, 2015 07:37 AM
