MTH Discussion (Archive) Have or interested in MTH software upgrades for your MINI? This is the place! Sponsored by MTH.
Running original MINI file with the MTH header?
Old Jan 4, 2006 | 08:05 AM
Maaij's Avatar
Maaij
HI
I have a MTH header with the MTH special tuner file.
My question is:
Can I run the MINI with MTH header with the original MINI file (not the MTH file)? e.g for warranty issues?
I heard this is bad for the cat and engine.
Anyone know if this is true?
Thank you
Old Jan 4, 2006 | 11:41 AM
BMDoubleU's Avatar
BMDoubleU
Originally Posted by Maaij
HI
My question is:
Thank you
its OK, but you might get a p-code when cold starting around 0degrees C.. no-precat AND cold weather makes stock software think you don't have a cat.. under normal operating temps, it stock software will do just fine... (been there and done that) btw, you could ask the guys at MTH to send you a file with stock red line and throttle sensitivity so, you dont have to worry about warranty concerns and keep your gains..
Old Jan 4, 2006 | 12:28 PM
Maaij's Avatar
Maaij
Thanx for your reply
If I do that. Will I lost some performance gains? What will the throttle sensitivity do? Sorry, I am not an expert in this stuff
Old Jan 7, 2006 | 08:37 AM
BMDoubleU's Avatar
BMDoubleU
i am not sure if throttle sensitivity makes a difference in power. i know that it makes a difference when driving. if you take your car to the stealership they might be able to tell that your ECU has changed when 80%power is available at half pedal travel... keeping your stock setting will allow them to think its still stock. (you A/F maps would still be installed and making HP)
hope that helps
Old Jan 10, 2006 | 01:41 AM
Volker@MTH's Avatar
Volker@MTH
You can run the header with the standard SW for a while. No problem.
minicoclub
Nov 11, 2015 07:25 AM
vballkid77
Cooper (non S)
Aug 10, 2015 04:44 PM
Dashdog
Aug 10, 2015 06:17 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
