MTH Discussion (Archive) Have or interested in MTH software upgrades for your MINI? This is the place! Sponsored by MTH.
ASC modification by MTH?
Old Oct 30, 2005 | 04:23 PM
OldRick's Avatar
OldRick
I understand that MTH modifies the ASC to reduce its intrusiveness.
I have an `05 with factory LSD, but the ASC "traction control" still kicks in way too easily, and I'd like to raise its trigger point and instead depend on the LSD to do its job instead. I'll happily sacrifice some tire wear for better control over the car and the engine.
My question is whether the Standard MTH remap modifies the ASC to raise its trigger point or if the Tuner version is necessary for this change? Also, could I could get a Standard or Tuner version that would REALLY cut back on ASC - like so it almost never operates?
Old Oct 30, 2005 | 06:01 PM
DarkMiniCooperS's Avatar
DarkMiniCooperS
both standard and Tuner MTH software have the ASC/DSC mod.
I think MTH is the only software/ECU remap to modify the ASC/DSC traction control, and it works great! I see the difference every winter when it snows!
Old Oct 31, 2005 | 06:11 AM
tradiuz's Avatar
tradiuz
MTH Specialist
Standard and Tuner both modify the ASC/T and DSC. For having it almost totally disabled, you'd be better off with Ian Cull's Auto-Up Circuit w/ Track Day DSC. I leave the modified DSC on all the time (except when on the track) and its not as intrusive, and it has saved my behind more than once.
Old Oct 31, 2005 | 06:59 AM
OldRick's Avatar
OldRick
I guess I should re-phrase my question:
It is my understanding that the factory LSD feature modifies the ASC feature to be at least somewhat less aggressive about quelling wheel slip.
Does the MTH mod do even more than the factory LSD change to ASC, if LSD is installed?
Pker
Apr 11, 2017 12:14 AM
vulkandino
Oct 31, 2015 08:29 PM
ryGuyMCS
Oct 6, 2015 12:04 PM
point665
Sep 29, 2015 12:41 PM
R53UndaPSI
Sep 21, 2015 09:42 AM
